peugeot 206 is working
08.05.2020 21:25 # 1
umut1001
Hello. My car 206 2008 model gasoline automatic 1.4. No lpg at 147000km.
The car did not work in the morning two weeks ago. It worked when I went the next day. It did not work again in the morning after 1 week. I bought a battery and it didn't work.
The starter is running but the car is not running. What could be the reason?
So this car works sometimes depending on the head, sometimes does not work. Strange situation.
It was mentioned that the battery chassis cable was molding somewhere. Is that the case?
Thanks.
umut1001 2020-01-09 00:43:33
08.05.2020 21:25 # 2
omerb
Brother, I do not understand if you are getting in the car every 2 weeks.
08.05.2020 21:25 # 3
umut1001
No, the vehicle is running between those times. It gives a malfunction in the week.
08.05.2020 21:25 # 4
omerb
Maybe there may be a problem with the starter. If you go to the electrician, they will measure and look.
08.05.2020 21:25 # 5
Yasam79
Man, I had the same problem, the brain man came and put another brain on the car, all my problem was solved. Then he threw a program into the current brain, put it back in the car's own brain. Everything is super right now. I say show it to a cerebellum. Mars was printing but my car was not working. Everybody said something
08.05.2020 21:25 # 6
umut1001
Slm. How much did it explode? I think there might be a crank sensor too. The sensor could not read when the top was lubricated.
08.05.2020 21:25 # 7
Yasam79
I bought about 300 from me, then I had no problems. I think it's a show.
08.05.2020 21:25 # 8
ismailkaya
look at the immobilizer of the key.
08.05.2020 21:25 # 9
umut1001
I looked at the immobilizer. He said that the keymaker is working. I'll look at the errors with the bluetooth device tomorrow.
08.05.2020 21:25 # 10
umut1001
In recent months, when I pressed the key with the key, it opened the door after two or three presses. Even though I pressed it, I could not open the door. I opened the door and closed the door by inserting the key. umut1001 2020-01-11 00:12:28
08.05.2020 21:25 # 11
Yasam79
I have the same problem on the right front door, it gets stuck on the head. Sometimes there is no problem, sometimes the doors are closed from the lock and open back. So I close it with the key. I couldn't solve the problem now.
08.05.2020 21:25 # 12
umut1001
It is interesting that I installed the OBD2 device today, I searched for errors on the phone, it did not find any errors. I removed the battery, I am charging it at home. Let's see what happens next time.
08.05.2020 21:25 # 13
omerb
[QUOTE = umut1001] In the last months, when I pressed the key with the key, it opened the door after two or three presses. Even though I pressed it, I could not open the door. I opened the door and closed the door by inserting the key.
Is your problem not working?
08.05.2020 21:25 # 14
umut1001
Friends removed the temperature sensor and put it on, the vehicle worked!
08.05.2020 21:25 # 15
umut1001
I started the car today. I went to pick up the boy from school. I stopped by. I came back again.
08.05.2020 21:25 # 16
Yasam79
You listen to me, show me to a brain driver, believe my problems are solved like this
