Peugeot 206 ignition malfunction
08.05.2020 20:01 # 1
monalos
Hello there,
I have a problem like this, I would appreciate if you write your comments and suggestions
The car is 2002 206 1.4 petrol, it reacts late when I press the gas, but there is no problem when it goes, 190 comes easily, the gas reacts late when I gas it.
08.05.2020 20:01 # 2
throttle and idle sensor
08.05.2020 20:01 # 3
monalos
I started to hear the engine noise more and the accelerator pedal vibrates, which may cause
08.05.2020 20:01 # 4
talip206
respectively; throttle cleaning, spark plug and coil should be checked, coil changed but compatible. Some sub-industry coils can cause trouble. start with throttle cleaning first.
08.05.2020 20:01 # 5
monalos
There was no time when I first installed the coil, this problem went a long way after that, these troubles started
08.05.2020 20:01 # 6
koray.turan
Replace the spark plugs and clean the throat butterfly.There will be no bumps. I had the same problem.
08.05.2020 20:01 # 7
monalos
Thank you, I will report the operations and malfunctions in detail when I go to the service.
08.05.2020 20:01 # 8
lodos41
I had the problem of late reaction when it was loaded into the gas. No more trouble when the spark plugs changed and clear the throat butterfly.
