Peugeot 206 Idling Sound
08.05.2020 20:51 # 1
samet206
Hello, I would appreciate if anyone has an estimate that I have a question, the vehicle 206 sounds as if it was idle at first start, it sounds like it was left without oil. There is no sound left when it warms up and moves anyway, is there any guesses?
samet206 2018-04-24 02:04:24
08.05.2020 20:51 # 2
breakbeat
For example, you stopped in the light after moving, is there the same sound again?
08.05.2020 20:51 # 3
samet206
Not that way, if the vehicle stops at the lights after moving and warming up, pausing at idle, the sound does not come any more.
08.05.2020 20:51 # 4
breakbeat
The only thing that comes to my mind is that your engine water may be antifreeze free.
More experienced users will surely help better.
08.05.2020 20:51 # 5
samet206
There is no such possibility as the periodic maintenance is done by me, I have reset the other necessary cooling system parts, including radiators and hoses, in December 2017, the production of high quality blue antifreeze last year, which I have not connected to this situation. If I can predict the malfunction, I will have to show it to the service, I wonder if it causes a problem like steering box or something, I could not understand it, if there is a suggestion, I follow it, thanks for your attention ...
samet206 2018-04-24 02:02:50
08.05.2020 20:51 # 6
possibly due to v-belt and bearings
08.05.2020 20:51 # 7
breakbeat
I was going to call the dynamo bearing, but I was eliminated because it said it doesn't do it when it gets hot. Last week, I had a despicable voice in idle. The gas was going to press the pressure again, idling again, there was the same sound. I changed the bearing and it got better.
08.05.2020 20:51 # 8
samet206
Thanks for the suggestions, let's look at the service at the appropriate time, if we can solve it, I will add the solution of the problem here.
08.05.2020 20:51 # 9
samet206
Hello friends, I was told that the sound I was talking about was coming from the alternator, I solved the problem.
