peugeot 206 idling problem
08.05.2020 15:32 # 1
powerclub206
Hi guys. I run my car sometimes it works like a low speed stop etc .. sometimes it works at high speed. when I push the vehicle a little bit, the dipstick sees 90. why are these happening? what's wrong with my car the albaydemirc 2011-06-07 08:54:30
08.05.2020 15:32 # 2
First, clean the throttle. Most likely the problem will be solved.
08.05.2020 15:32 # 3
powerclub206
What is the throttle?
08.05.2020 15:32 # 4
hunterakon
If the throat throttle, which is connected from the outlet of the gas butterfly throat air filter box, is cleaned in a clear map sensor, it will not be a bad try.
08.05.2020 15:32 # 5
powerclub206
Thank you so much :)
08.05.2020 15:32 # 6
emrnl
[QUOTE = Berkay] First clean the throttle. Most likely the problem will be solved. [/ QUOTE]
+1
08.05.2020 15:32 # 7
se®k@n
I also think it might be from the throttle first.
08.05.2020 15:32 # 8
powerclub206
I went to the industry, it is very interesting that the master opened the hood, looked at the battery (-) the pole was loose, squeezed it and passed, could it be something like that :)
08.05.2020 15:32 # 9
[QUOTE = powerclub206] I went to the industry, it is very interesting that the master opened the hood, looked at the battery (-) the pole was loose, squeezed it and passed, could it be like this :) Anything does not say that it is flying for 4-5 days.
What a beautiful master, if he had a pressure, he'd get a fuckin 'together Göz Kırpma
You should have already maintained the battery terminals as a vehicle owner. Whether it is loose or oxidizing or not, whether the water level is ok or not. In the comments here, it is not even a matter of fact, considering that you have already made / do such minor but important points. Get well soon.
