Peugeot 206 Headlight and turn signal malfunction
08.05.2020 19:12 # 1
bozlak
When my car's headlights turn on, when it signals, the headlight goes off and the signal lights up a few times then turns off by itself.
08.05.2020 19:12 # 2
talip206
Repair is done, but you need to find a good electrician, because the airbag steering wheel or something must be removed to remove the signal lever. The bidet signal arm is very expensive because the wiper arm is combined. The price is between 700 and 700 TL. (Compound in most 206 models) talip206 2015-04-09 13:49:26
08.05.2020 19:12 # 3
mightlacin
brother, first of all, I say change the fuse that concerns the signal arm from the fuse box under the steering wheel.
08.05.2020 19:13 # 4
blntctn
[QUOTE = talip206] Repair is done but you need to find a good electrician, because the airbag steering wheel or something must be removed to remove the signal lever. The bidet signal arm is very expensive because the wiper arm is combined. The price is between 700 and 700 TL. (Compound in most 206 models) [/ QUOTE]
teacher, let me fix it, no mistake, I changed it 1 week ago when it is completely sensored, 390 TL without sensor, they get 40 TL in 340 TL workmanship zero and original
08.05.2020 19:13 # 5
talip206
[QUOTE = blntctn] [QUOTE = talip206] Repair is done but you need to find a good electrician, because the airbag steering wheel or something must be removed to remove the signal arm. The bidet signal arm is very expensive because the wiper arm is combined. The price is between 700 and 700 TL. (Compound in most 206 models) [/ QUOTE]
My teacher also sent the chassis number to the malfunctioning site manager gökhan bey. the original is 610 tl and the french valeo brand is 450 tl. Mine doesn't have a sensor either. Frankly, I didn't get a price elsewhere. That's why I said that price. I haven't done it yet
08.05.2020 19:13 # 6
blntctn
[QUOTE = talip206] [QUOTE = blntctn] [QUOTE = talip206] Repair is done, but you need to find a good electrician because the airbag steering or something must be removed to remove the signal lever. The bidet signal arm is very expensive because the wiper arm is combined. The price is between 700 and 700 TL. (Compound in most 206 models) [/ QUOTE]
My teacher also sent the chassis number to the malfunctioning site manager gökhan bey. the original is 610 tl and the french valeo brand is 450 tl. Mine doesn't have a sensor either. Frankly, I didn't get a price elsewhere. That's why I said that price. I haven't made it yet [/ QUOTE]
price is expensive As I said, I bought 340 sensorless, 390 sensor price, and the piece was another brand that was fitted with a valeo.
08.05.2020 19:13 # 7
talip206
He was fine then. I was surprised when I got that price. The signal arm makes me nervous. I am afraid I will have an accident someday. It burns according to your head, mislead your back, and I'll hit somewhere to fix it
