Peugeot 206 headlight adjustment
08.05.2020 15:57 # 1
Gokhan_S
friends how should my 206's headlight adjustment be, there is an icon on the left bottom of the steering wheel 0-1-2-3 .. when I turn it, for example, when I turn it from 0 to 1, the headlight rises slightly, in the same way 2-3-4 In your opinion, what range should the ideal setting be?
08.05.2020 15:57 # 2
0 is the highest, 4 is the lowest. It is a must for water. Rather than adjusting the height adjustment, the headlight itself needs to be looked at. What do you know that the setting was correctly made ???
First of all, when position is 0, headlight adjustment should be done and it should be used in this way. If the vehicle is placed high, the headlights will be raised because the rear is down. According to your needs, you can download and use 1-2-3-4 etc. When you empty Yuku, you bring it back to 0. Otherwise, the headlights start to look at the ground ... the cecol 2011-08-07 00:08:18
08.05.2020 15:57 # 3
oguzhan29
thanks for sharing
08.05.2020 15:57 # 4
cecoli has been poured again .. scholar health cecolim ...
08.05.2020 15:57 # 5
[QUOTE = cecol of]
First of all, when position is 0, headlight adjustment should be done and it should be used in this way. If the vehicle is placed high, the headlights will be raised because the rear is down. According to your needs, you can download and use 1-2-3-4 etc. When you empty Yuku, you bring it back to 0. Otherwise, the headlights start to look at the ground ... [/ QUOTE]
++++ Gülme
08.05.2020 15:57 # 6
just like cem bro inventor Gülme
