Peugeot 206 hdi Basma
08.05.2020 19:10 # 1
pressoke
I have a Peugeot 206 hdi car and I want to print it. And there are many ways of pressing techniques, from spring cutting to hold coilover. You recommend Haingi. Can you write positive and negative aspects.
08.05.2020 19:10 # 2
fætih
I do not recommend cutting. I do press it, it does not recommend it, it disrupts the strength.
08.05.2020 19:10 # 3
Adem Kurtuldu
If you want to be simple, eibach 5cm spring or coilover others are not healthy, or cut or press on the highway or there is a risk of spring breaking and bowing.
08.05.2020 19:10 # 4
ege55
I asked today, they said, let's make it 3.5, 5cm bow does not print 5
08.05.2020 19:10 # 5
aslanaft
I think I have a bow, I will give it suitable 5 cm.
08.05.2020 19:10 # 6
aslanaft
http://forum.peugeotturkey.com/forum_posts.asp?tıd=40584&title=mrb-konyadan-ali-ben-selamlar-herkes to
08.05.2020 19:10 # 7
Gokcesel
[QUOTE = aslanaft] I think I have a bow, I will give it a suitable 5 cm net, I will send a picture, I have sent the fall [/ QUOTE]
What is the brand of springs? I was thinking about wearing a 16 rim and 3.5 springs but 5 cm would be too much :)
08.05.2020 19:10 # 8
Adem Kurtuldu
Whoever says 5 does not leave the heat, the 3.5cm plateau tool will be 3.5cm alcaline 5cm al 5cm alcali naturally will take 5 cm more naturally. 15-minute spring plug is more comfortable and convenient than plug
08.05.2020 19:10 # 9
samet206
Hdi engine is a bit heavier than gasoline, depending on how much you want to press, if you put a 3.5 cm spring on the gasoline vehicle, maybe it will not be satisfied, but it goes away. Coilover, sports spring and air suspension remain, air suspension is an expensive system. Our vehicles also have a torsion system. I do not know about the setting or something, I think it is a preference.I think the most logical is to use a high quality sports bow.
samet206 2016-02-03 01:24:26
08.05.2020 19:10 # 10
yawruaslan
3.5 cm does not work, I recommend you to install a 5 cm sports spring first. You can lower the car with the coil in 5-10 minutes.
https://www.youtube.com/watch?v=hi6zpwrq94 to
[TUBE] hi6zpwrq94 A [/ TUBE]
the yawruasl 2016-02-03 13:31:15
