Peugeot 206 hdi 1.4 van Selector problem..Help.
08.05.2020 16:34 # 1
gabriel
Friends, peguet 206 hdi I bought a 1.4 van car. output. I went to the auto electrician and said that the fuse box should be changed. There is no problem when the headlights are lit.It is normal.
08.05.2020 16:34 # 2
gabriel
No one will answer ..?
08.05.2020 16:34 # 3
I guess you checked your insurance? It has a 15 Amp fuse and is located in the fuse panel in the engine section.
08.05.2020 16:34 # 4
gabriel
Hello, I checked the insurance. I asked the friend I bought the car. When the headlights started to burn long, I took out the fuses. When I put the fuses back again. I took it to another place. He said it might be in the room relay or installation .. I don't understand .. If there is a problem in the fuse box, do you think other places will work. not burning the longs and there is no problem outside the selector right now ..
08.05.2020 16:34 # 5
Anything else is not left behind anyway. Malfunction, either in the role, in the installation or on the arm, since it is not in the lamp. It seems to me that he was open to the role. It looks like you have no other choice but to trust the electrician.
08.05.2020 16:34 # 6
gabriel
thank you for your attention ..
