Peugeot 206 Gti Stop
20.05.2020 09:21 # 1
canbolat66
Good forums, first of all, I am new to the forum and I didn't know where to open the topic. When the heat sensor of my vehicle had cooled down for 1 month, I had to pull it off in the morning and keep track of the plug after a little heat, and it did not cause any problems, but the vehicle was suddenly stopping at a distance of 100 km on the road until 1 week, and the interval of the stopping was made at a distance of 10 km or 20 km. the vehicle is instantly stoppages, I brought the car to the master for 20 days. Can I help you with problem information? The vehicle has been in the industry for 20 days.
20.05.2020 14:18 # 2
ismailkaya
Unplug the lower oxygen sensor and use it like that
22.05.2020 13:50 # 3
canbolat66
Hodja, he still has not been solved.
22.05.2020 17:27 # 4
ismailkaya
Is your car's stop problem going in gear?
22.05.2020 18:59 # 5
canbolat66
My teacher had a bad heat before the morning, he took the muur in the morning and when the temperature of the engine was 30 or so, he would wear the plug, but he wouldn't even eat mars. believe what the reason is, I did not solve it, they said the driver of the car got to the industry, they changed it, they said the transmitter, they changed the sensor, and now they are throwing the water into the brain, and if we come to stop the vehicle, my teacher. There is no lousy master in our industry. vs a lot of things have changed. I paid 1,200 TL. There is still no change in the industry. We are connecting from the computer. I can check individually if you have anything to recommend
22.05.2020 19:01 # 6
canbolat66
It doesn't matter whether the car is in gear or at a gap, it will self-stop
29.05.2020 16:05 # 7
canbolat66
The problem has not been solved yet, there are no friends who come to you.
29.05.2020 16:21 # 8
bro, did they check the engine ecu cables and sockets. It may also contain a gas pump and a return valve per thousand but as you said, if you couldn't find a master who understands, I would help the master if you were in distress. It is necessary to remove the engine ecu sockets and clean them with oil-free contact spray.
29.05.2020 16:31 # 9
From here, you can enter the chassis number of the vehicle and reach the place of your choice. https://partsouq.com/en/catalog/genuine/vehicle?c=peugeot&ssd=%24%2akwh2wto8spl2sıkziyn73q66mp2d8v3w8epw7rcgpay2vıgv-fbpgoaw8_t08r7r9uetpq6mhl7grft3ret_4uh1lzbxv7-v5qs2t7asolo_s7xknucb9ıty8b-_ryb1hpws5-7i36pı9pdg7-ah8otcok2zuaaaaac04d6q%24&vid=0&cid=78&q=
