Peugeot 206 front fog activation
20.04.2022 12:34 # 1
ByYlmzZz
Hello, I have a 2004 model 1.4 x-line vehicle. There is an indication on the signal arm showing both sides of the fogger. I found some topics in this forum, but the pictures are gone due to timeout. I will take care of the buffering part. I I want it to be original, so I want to handle it with the signal arm.
After activating it with software, I couldn't find out how I would have to follow the electrical installation. So is there an infrastructure ready? If not, where should I draw this line? I want your help on this.
20.04.2022 13:05 # 2
ByYlmzZz
Additional note : There was fuse no. 6 in the bsm inside the engine and a 10a fuse was installed.
20.04.2022 18:14 # 3
there is a missing role in the engine fuse box bro, it needs to be done. you could use the arm as original. I'll do some research and if I can find old threads I'll post it.
21.04.2022 01:39 # 4
ByYlmzZz
@sonerkyl, I mixed old topics, there is a detailed topic, but the pictures do not open. Also, my bsm is delphi brand. There is no fuse and relay according to the subject, but I have a fuse and even 10 amps are installed. I need to open the bsm and see if there is a relay, but I guess there is. because when I wanted to do other equipment, I saw that there was all the infrastructure (eg made up to the socket for the trunk lamp, there is even a sensor for the outside temperature indicator). How can I understand whether there is an installation in this vehicle?
23.04.2022 09:03 # 5
ByYlmzZz
does anyone have any knowledge?
24.04.2022 21:56 # 6
ByYlmzZz
current
09.05.2022 23:56 # 7
ByYlmzZz
I opened the inside of the bsm and it is present in the relay connected to the fuse number 6. So there is the electrical infrastructure as the original. There is also a socket fixed to the chassis with rubber behind the left headlight. I say it's probably for the fog, but what do you think?
