Peugeot 206 Flip Switch
08.05.2020 17:56 # 1
halilefe
Friends Mugla / Ortaca also did not find the keymaker to turn the peugeot 206 key box into a switchgear.
08.05.2020 17:56 # 2
halilefe
Will I also need to supply a chip for the snap wrench or will it fit in the new case?
08.05.2020 17:56 # 3
Barut
I bought it from the internet, I had no problems, the chip fits easily.
08.05.2020 17:56 # 4
halilefe
So from which site
08.05.2020 17:56 # 5
Alicilik
I brought it from abroad. There are 4-5 kinds. The best key is the vertical penetrator. It fell more than 20 times, washed 1 time in a pocket. I have been using it for 1.5 years. It was more common than I used before. As you said, the key did not last, and the key began to swing.
I used the previous
Over time, the key began to play and the buttons were worn.
This is the new one
more versatile and quality. The key does not play because it enters upright.
I changed both of them easily. Be careful when buying, the appearance for 207 and 206 is the same, but the end of 207 is not drawn straight to 206.
08.05.2020 17:56 # 6
halilefe
Which site did you get from Ustad Tongue
08.05.2020 17:56 # 7
halilefe
When I said I had to pull the tip, I didn't understand it
08.05.2020 17:56 # 8
Alicilik
I bought it from ebay teacher.
The iron part I call the tip. Since it is new to you, you will be trackless and you will have it pulled. So you will copy. After copying, try both doors and warehouse, sometimes it can cause trouble in the warehouse.
08.05.2020 17:56 # 9
abdullahaydn52
[QUOTE = Buying] I bought it on ebay, hodja.
I made the switchblade contact, and there is no problem in the warehouse alone, it does not open and lock the doors. For now, we can handle it from the remote, but I don't know what to do if there is a problem in the future.
08.05.2020 17:56 # 10
C@GL@R
I bought it from the virtual market, 18 lira is not something that will dissipate quickly, it takes 5 years from the head.
08.05.2020 17:56 # 11
ahmed206
We've gotten the subject down, but I know there is a keymaker who can do this job in Ortaca. Her son is in Dalaman. I know your son.
08.05.2020 17:56 # 12
stkkonko41
I had it done in izmit in industry as a keymaker. 10 min. They give the key. I have been using it for about 6 months. I have no problem.
08.05.2020 17:56 # 13
alperuzuntas
[QUOTE = abdullahaydn52] [QUOTE = Buying] I bought it on ebay, hodja.
Insert the key, move it 1 click forward, the car will not start, only the indicator lights are on.
Press the lock button on the key for 10 seconds, turn off the ignition. try it like this, if not
try the same operation by pressing the unlock button for 10 seconds.
In other words, it is necessary to introduce the control to the car for a solution.
08.05.2020 17:56 # 14
outlaw
I HAVE MADE IT TO THE KEY AND I WAS VERY SATISFIED CHIP WORK HOW I WAS HANDLED 2 YEARS.
08.05.2020 17:56 # 15
herry
there are friends who are satisfied, i read from here but maybe i dont know was the poor quality i got. I had a snap with 206, I did not know how to describe those who opened the slap with the back of the hand when I pressed the button :). At the end of the year, the key had started dancing in the container :) I returned to the original.
08.05.2020 17:56 # 16
ahmed206
I was not surprised by the original, took the key container and continued on the road. I don't regret Big smile
08.05.2020 17:56 # 17
akantek
I turned back to snap! While returning, I made a switchblade on the spare key. Yes, there are slacking over time, but I occasionally tighten the screws with the watchmaker screwdriver. it is like stone. now I will squeeze the silicone on the bottom of the key and see if it will relax again?
When it came to the chip event, they got it in 1-2 hours when there was a barrier who knew how to do it. Even if the chip does not fit, they install a new chip and adjust its frequency or something. it's not a big problem.
akantek 2014-05-01 09:11:56
08.05.2020 17:56 # 18
cemz
you need to have someone skilled in the forum that a friend of ours didn't work, just because of these changes
