PEUGEOT 206 FEAR OF HATE |
• Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206 |
30.05.2022 14:33 | # 1 |
I wonder if these values are normal? Or is it a malfunction? I'm a beginner, I'd be very happy if you could help me with this. Many thanks to everyone who replied in advance.
30.05.2022 14:34 | # 2 |
In addition, I made frequent stop and go because of traffic.
31.05.2022 08:55 | # 3 |
good luck with your car. In diesels, it usually goes above 90 on the indicator, then 90 should be fixed as it moves. The biggest problem of the cooling system of the vehicles is the use of antifreeze. Is there antifreeze in the vehicle or the job can be quite costly. water makes rust and sediment everywhere. then replace the parts in the stop cooling system. First of all, if you can get an obd device, check it digitally for 60-70 TL.
31.05.2022 10:40 | # 4 |
maybe you didn't hear it in motion. or you can warm the engine where it stops. that's how you look. or take it to the master, he will check it.
03.06.2022 13:01 | # 5 |
Hello, My vehicle is a 2008 model gasoline 1.4 automatic, I use the bridge every day, because there is no traffic in the morning, it does not go above 85, but when returning in the evening, if there is a very strange congestion around 93, it comes to 97 and 90. a falls back in seconds. Taking into account the age of the car, I started to turn on the air conditioner at 1 am if there was a traffic jam in the evening. Since it works with 2 fans, the temperature does not exceed 90. It is true that the engine is loaded, but the car does not go in traffic anyway. For your information, other friends I asked told me not to take any action on the vehicle.
10.08.2023 00:42 | # 6 |
In my diesel, the fan turns on at 97 degrees, generally it turns on at 97 degrees. Diesel Peugeots run hot and hot. The engine overheats. In places like Şanlıurfa, where temperatures reach and exceed 50 degrees, when you do a lot of stop-and-go, the fan turns on, but it turns on above 90 degrees. As you move, it increases and fixes it at 90 and a little below.
