Peugeot 206 Does Not Work Absolutely In The Morning HELP
08.05.2020 19:07 # 1
ozkydz
Hello friends peugeot 206 Ranold Garros 1.6 my car does not work in the morning.
Gasoline Filter
Gas Pump Float Included
Heat Sensors
Injection cleaning and settings
Throat Butterfly cleaning
Valve Settings Made
Battery changed
Gas Brain
I spent 1000 TL, but futile vehicle does not work in the morning. I was desperate
08.05.2020 19:07 # 2
ozkydz
If you have knowledge or have had the same problem, I request your help.
08.05.2020 19:07 # 3
Efe-Pojo
Doesn't it work on gas?
08.05.2020 19:07 # 4
vpro
Hodja, if you followed a very wrong tactic. If the car is not working, it means that it does not work when it is cold in the morning. Secondly, where is this gasoline going through (I do not know exactly) I would have looked at it, you changed the pump or something.
08.05.2020 19:07 # 5
talip206
As far as I understand, you have made your expenses in vain. Probably the master has said that it has not been there, it has changed everything in vain. First of all, find a good master. perhaps it is so simple that the master has not noticed. Like a hose cable break
08.05.2020 19:07 # 6
fætih
Is the regulator checked? Was LPG disabled in the vehicle and used in 1 2 days gasoline?
Does the vehicle work as if drowned after starting?
connected to the computer and learned the error code?
08.05.2020 19:07 # 7
sezar206
Get well soon.
08.05.2020 19:07 # 8
ozkydz
We have connected the computer, there is no error, the hoses and the engine part were checked 3 or 4 times. I traveled an average of 450 km for 4 days with lpg petrol, but unfortunately the fault continues. The vehicle does not run in the morning. in gas, I barely move. once it gets warm, it works like a clock
08.05.2020 19:07 # 9
ozkydz
Thank you for your attention and your answers. Unfortunately, the problem continues. I don't know what to do around 300 TL. Three Master looked today, but we haven't found a solution yet.
08.05.2020 19:07 # 10
fætih
temperature sensor temperature sensor check them.
If bsi is reset, reset it.
look at the gas pump. If there are cracks in the pipes, it creates pressure loss.
Lift the back seat without starting the starter and hit someone like a snare player on the petrol pump.
may be from the latest brain
08.05.2020 19:07 # 11
ozkydz
I tried that starter thing, no problem, how can we understand that it is from the brain? no error code
08.05.2020 19:07 # 12
ozkydz
I know I spent a lot of money
08.05.2020 19:07 # 13
trabzonlu207
[QUOTE = ozkydz] Well, I spent a lot of money [/ QUOTE] I've looked at what he did to solve the problem. The world has spent money. I hope you will solve the problem in a short time
08.05.2020 19:07 # 14
talip206
You can also try this. In the evening, before stopping the vehicle, put it in petrol 3 4 minutes, work it that way, then stop. In the morning, will there be a working problem? What is your gas status, not under the quarter tank. Sometimes problems arising from the lpg brain can cause this problem. Yes, it may sound irrelevant. Some may say what the vehicle has to do with LPG already runs in the morning. But what happens to most people talip206 2015-02-26 21:26:19
08.05.2020 19:07 # 15
ozkydz
Thank you for your answers and interest. But I tried 5 minutes before parking, I closed the LPG and used it in gasoline, and I parked it, but unfortunately, the same disgrace is going on in the morning. it certainly didn't work. I even tried to reduce the tank very much and renew the gasoline in the tank, but believe me, I have no patience, and I have no strength to bear. I'm done now ...?
08.05.2020 19:07 # 16
reclove
I had 98 models and 306 complete recipes. the same problem started to occur in me. The vehicle, which had bought a single starter even in the cold before, now extends the starter very much. When I took it to the master, he told me it was due to the recycling valve. but I can hardly trust.
08.05.2020 19:07 # 17
vpro
Friends have you searched from English forums or something?
08.05.2020 19:07 # 18
talip206
Well, my friend, we were as sad as you, I investigated a little yesterday. Everybody says something different. But there was one thing that caught my attention. Someone found a solution by changing the morale. The engine was protecting itself because it was out of order. It made sense to me, but I don't know. I wish we could help if there was anything else we could
08.05.2020 19:07 # 19
Emask
My friend is always inspecting the induction coil with a new one in the authorized or special service, the first time in the morning.
08.05.2020 19:07 # 20
ozkydz
Thank you very much for your answers, friends worked for the first time this morning, but it happened after a long starter, but as you say, the air temperature has been very good in Ankara for 2 days, the coil event started to lie on my head.
Page : / 2
