Peugeot 206 Dodik (Fender Extension)
08.05.2020 19:28 # 1
samet206
Hello friends, I came across dodic works on the internet in the 206's, which I found abroad. In the fender areas. It is very annoying in terms of image. So if I wear such a piece, I think it would be possible to avoid it. Also, I think it is suitable as an image. If I can find the parts I want to work on ...
Sample ;
08.05.2020 19:28 # 2
serdaralisan
Hello teacher, we made of fiber before, draw and cut according to the fender mouth from the cardboard. you measure and cut it, and even there are many people who do not know this rubber dod, I bought it with the box.
08.05.2020 19:28 # 3
samet206
First of all, thank you for your attention. I know the rubber dods you mentioned, and I came across it when I was researching it, but if I think that I want to paint the top in the color of the body like in the same example, I do not think how to make a fiber. It is made exactly by taking the mold, but I do not know about the fiber without the mold, but I can think about the fiber.
08.05.2020 19:28 # 4
serdaralisan
teacher mold, you already have the vehicle, your mold is wide 8 inches maximum is okay, then the paperboard is taken, you draw and cut according to the fender mouth. With cutting, you will do this to easily curl that part just as you cut it, then let it come out of the inner part of the cardboard that will come to the fenders, then stretch it with paper tape towards the lower part of the cardboard, and make the dodic appearance with the tape. ok or you can use polyurethane, that is, you can shape it by using the door mounting foams that increase when you tighten it.
