Peugeot 206 dashboard table
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:11 # 1
kitay
Gokhan 2010-03-11 10:58:24
08.05.2020 14:11 # 2
kitay
slm friends I hope it works well when i bought a car i did not know what a sign meant, though i will not fail to learn to burn any sign that will fail.
08.05.2020 14:11 # 3
thanks for sharing
08.05.2020 14:11 # 4
FTH
Healthy sharing Tşk
08.05.2020 14:11 # 5
Haci
Health labor to your efforts. Thank you.
08.05.2020 14:11 # 6
GokhaN
edited your message thank you for useful sharing
08.05.2020 14:11 # 7
kitay
how happy it was for me
08.05.2020 14:11 # 8
[QUOTE = kitay]
08.05.2020 14:11 # 9
I'll ask for something, I bought a new car, the light contact 17 burns for 2 seconds, and then it should turn off
08.05.2020 14:11 # 10
Melih
thank you very much
08.05.2020 14:11 # 11
Is the dashboard chart on the 206 xs 1999 model? Confused
08.05.2020 14:11 # 12
YES 17 MOLU LIGHT IS UP TO 2 SECONDS AT ME, BUT IT IS NOT SOMETHING, EVEN THERE IS NO ROUTINE EVEN IF I HAVE WATER IN THE FILTER.
08.05.2020 14:11 # 13
idoberk
yes thank you. diesel water level light is the fault in me
08.05.2020 14:11 # 14
206hdisw
The warning light number 11 is on me, it stops when I press the gas a little more, there is no problem at idle and the air here is -20 degrees. What is the reason?
08.05.2020 14:11 # 15
senol73
Hi friends;
Which lights on this instrument panel should blink temporarily when we turn on the ignition of our vehicle?
the glow plug lamp I know is on and we have to turn the ignition after it goes out.
For example, this is not lit at all in my vehicle. How else can we tell if the lamps on this instrument panel are working? If some of the malfunction indicators have a broken light or something, we can continue on the road without seeing the actual malfunction.
Many thanks in advance to those who have knowledge and answered ..
senol73 2012-03-01 22:08:14
08.05.2020 14:11 # 16
xpyhre
Number 5 warning light on the instrument panel is on steady. What is the reason? Abs is broken? There is a picture of a vehicle and a grounded road like 206 GTi Si, I would be happy if you help.
08.05.2020 14:11 # 17
black_rock
THANK YOU a useful sharing
08.05.2020 14:11 # 18
furkan111
xpyhre I have the same problem as my friend
Indicator The warning light number 5 on the panel is constantly on. What is the reason? Abs is broken? There is a picture of a vehicle and a grounded road like 206 GTi Si, I would be glad if you help.
08.05.2020 14:11 # 19
[QUOTE = furkan111] xpyhre I have the same problem with my friend
the number 5 warning light on the dashboard is constantly on. What is the reason? Abs is broken? There is a picture of a vehicle and a grounded road like 206 GTi Si knows, I would be happy if you help.
08.05.2020 14:11 # 20
furkan111
I understood ... I just bought the vehicle, the seller did not have the opportunity to look at it, the seller said to me there is abs.
Page : / 3
