Peugeot 206 coolant reduction
02.01.2022 00:57 # 1
Yeniuye35
Greetings friends, I have a peugeot 206 2004 1.4 petrol vehicle and it decreases half a liter of antifreeze every 300-400 km, what we did, we could not solve it, the masters say that there is no apparent leak, use it like this, the old car already says water reduction is normal, do you think I should solve this problem or continue like this
Parts replaced so far
Water pump
Spare water tank cap
Spare water tank radiator connection hose
div>
Heating radiator and pipes
Lpg pipes
The gasket test was done 2 times, the gasket is intact.
I would appreciate your help, thank you.
03.01.2022 18:07 # 2
Greetings,
have you checked the radiator? If it misses a small amount when it is hot, you cannot see it due to evaporation. If the backup water tank is old, it may leak through a capillary crack.
05.01.2022 13:27 # 3
talip206
Check the floor in the driver's cabin for wetness on the carpet.
05.01.2022 14:14 # 4
Yeniuye35
No, sir, the heater core has just been changed.
07.01.2022 14:12 # 5
Sail
not the heater core. the front radiator may have capillary holes. Have it checked. It was also very little for me. it was wet. even steam was coming out from the front of the car :) I changed it, the life of the radiator had come :)
14.01.2022 03:05 # 6
AdemUsta1
It has nothing to do with the fact that the car is old, there was a problem somewhere, this car is decreasing, I am a mechanic, I can handle the unsolved problems. I have my own place on the Anatolian side of Istanbul.
15.01.2022 09:34 # 7
karaca61
Hello Master Adem, where is your place, can you write your full address, have a nice day.
