Peugeot 206 Comfort 1.4 Gasoline Temperature Sensor
08.05.2020 20:47 # 1
emoem
Hello friends
I have a Peugeot 206 Comfort 1.4 Gasoline 2008 model car. Can I change the temperature sensor myself? my hand is prone to technical os. Can you give information about the process?
Best regards.
08.05.2020 20:47 # 2
maximusti
This is the piece:
This is the dismantling team video:
[TUBE] y9ysboma1c8 [/ TUBE]
important note: I have no knowledge of the vehicle's compatibility with the vehicle and the vendor.
If you have not received the part, be sure to search for the part that will fit your vehicle online.
08.05.2020 20:47 # 3
emoem
Thanks for the answer, but these videos do not show how they were changed. Is it enough to disconnect the cable first and then remove and replace the customer directly? is it also necessary to make an adaptation? or can I find out if there are points to watch out for?
08.05.2020 20:47 # 4
First of all, unplug the cable, it is comfortable. Have some clean water and antifreeze with you because when you remove it, some water will be drained. Pay attention to the tightening rather than the removal, do not overtighten.
08.05.2020 20:47 # 5
emoem
Hi
thanks for your answer
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
