peugeot 206 Com2000 problem
27.03.2022 17:57 # 1
Bastro12
Hello Everyone First of all
My Peugeot 206 2004 1.4i 75bg vehicle had an occasional stop problem when it got into potholes and bumps in the summer of 2021 or on a straight road. Then an auto electrician friend who said he could give a guarantee and solve it, solved the problem by changing the cables going to the inner brain, and my stop problem was fixed, but then the signal sounds before my stop problem, the door open warning sounds, etc. disappeared completely and when I gave the left signal in my vehicle, the headlights were turning on by themselves. They said it was from Com2000, so I found a slightly used Com2000 and had it installed for 1500 TL. he came to himself but by himself The headlight turns on, if I touch the lever so lightly, it turns off and then on again. I'll go back to my friend. I'm tired of showing, but I'm tired of this tool, friends, it's a dead end from the industry. What exactly is this problem, please do not spare your comments.
28.03.2022 18:11 # 2
Check the winding in com2000 first.
29.03.2022 18:17 # 3
Bastro12
Hello Sir
Yesterday, it didn't do anything for an hour while it was going full time, then it started again
I didn't understand when I said wrapping.
30.03.2022 09:44 # 4
https://forum.peugeotturkey.com /forum_posts.asp?TID=42448&title=206-airbag-horn-coil-repair ;
related topic
In other cases, there may be a problem with the handle on the difference arm or the feet.
The third situation may be a problem with the BSI brain.
30.03.2022 15:27 # 5
Bastro12
Thank you, sir, I told the master to see if there is a possibility of one of these, my brother said there is no problem, come and see, I will go and have it checked this Sunday afternoon. I'm going to have all the electronics checked, I'm thinking of fixing the stop problems, I don't know how long it will take, because I can't afford to buy a car, I think it might be very troublesome.
30.03.2022 16:08 # 6
You're welcome. I hope it will be in order and not bother you in the car, brother. Unfortunately, vehicle prices have gone up, I don't know where the end will be. good luck now
31.03.2022 23:14 # 7
Bayram96
There are those who repair the signal arm of the com2000, I wish you did not pay that much money and replace it completely 2 years ago, I had a new signal arm installed for 250 TL, I still use it without any problems.
29.06.2022 20:48 # 8
berkayakulker
Hello, I have a problem with my arm, do you know someone who can fix it on the European side of Istanbul?
10.08.2023 00:37 # 9
mahmut alpay
I had a similar problem. The electrician had replaced the one with the left arm signal with the film. I found it, but he told me which one to buy. There are two types, filmed and non-filmed. It was fixed when the arm was replaced, but I don't know how long it will last. There are a lot of electrical problems, unfortunately.
