peugeot 206+ clutch lining |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206+ | |
| 08.05.2020 17:10 | # 1 |
| 08.05.2020 17:10 | # 2 |
mev347 |
If you do not, the vehicle will drop from the traction and after a while you will stay on the road in a place that is not possible.
| 08.05.2020 17:10 | # 3 |
tellotello |
The results of this, as your friend says, your car drops out of traction, so you can not get a healthy ride, which is reflected in the consumption of gasoline and goes on to stay on the road after a while. In situations where the pressure pad ends, soon the gear shifts begin, the vehicle drops from traction and the fuel consumption increases. When you press the gas on the road, the speed increases, but if the vehicle does not accelerate, the pressure is over. If you do not do this and you do not trust the master, I recommend you to show it to other places. There are a few more ways to find out that the printing pad is over, but if you search for it on the internet, there are a few methods such as shifting to high gear, trying on the slope.
| 08.05.2020 17:10 | # 4 |
My teacher uphill in 1st gear after overturning the car, make full throttle and put it into 3rd gear. If the car is stacked, there is no problem. Try this tactic for a very short time and don't repeat it all the time.
| 08.05.2020 17:10 | # 5 |
KenBlockJR |
800-1000? printing pad price 200tl. 100tl workmanship even if the stone cracks .. & nbsp;
| 08.05.2020 17:10 | # 6 |
[QUOTE = KenBlockJR] 800-1000? printing pad price 200tl. 100tl workmanship, even if the stone cracks .. & nbsp; [/ QUOTE] Exactly, our price sponsor is the original clutch set of Şahin peugoetda 205 TL Click for link |
| 08.05.2020 17:10 | # 7 |
Thank you guys very much for your valuable thoughts, but my vehicle feels like normal, 5 gears 3 thousand revolutions at 110 km speed, the vehicle falls to 100 km on the ramp, as if the traction is normal, but I hope I get more information thanks to you.
| 08.05.2020 17:10 | # 8 |
I do not know Istanbul, but in Ankara, the clutch set of Valeo brand is 140 lira on the topic but we will:) & nbsp;
| 08.05.2020 17:10 | # 9 |
the price has attracted more than the truth .. even in the authorized service this price does not hold .. I think a research ..
| 08.05.2020 17:10 | # 10 |
pressure pad is 200 TL or so, you will change the pressure pad while the axle seal will change in them. 40 TL fanal transmission oil will change 2-3 liters. Room 18 TL liters work in İzmir. it needs 30 TL. I changed it 1 month ago. 600 tl kept
