Peugeot 206 CC OV Knock Failure
08.05.2020 21:27 # 1
gorkemfidan
Hello friends,
I have a 2002 model 206 CC OV LPG vehicle. My car starts knocking at the gear changes for 5-10 minutes at the first start, until the engine temperature reaches an average of 70 degrees. First he contracts himself, then he moves to the next gear and jumps forward. After 5-10 minutes, it returns to normal when the engine gets hot. I changed the gearbox oil. Where can the problem be? Thanks.
08.05.2020 21:27 # 2
talip206
This kind of knock can happen when the throat butterfly is dirty. Clean and experiment beautifully. The throttle needs to cut off instantly when changing gear. When dirty, the reaction is delayed and knocking.
08.05.2020 21:27 # 3
gorkemfidan
Thanks
08.05.2020 21:27 # 4
EmSul
The same event is present in my 307 and after my warmth, it gives automatic gear fault error. Oil pressure regulation error comes out.
08.05.2020 21:27 # 5
gorkemfidan
We solved the problem of my pain. We connected it to the computer, it gave electroval problems, we changed them, we cleaned the hydraulic brain, we changed the oil, it kept 2000 liras, the hits were resolved.
08.05.2020 21:27 # 6
EmSul
I had the same procedures done 6 months ago, but there was a knock when it was not cold but now it was knocked when it was cold, now it does not knock when you move without waiting like you are running the morning tool in the cold.
Did you get it done at an authorized service, the price is quite high
emsul 2020-02-20 21:26:35
08.05.2020 21:27 # 7
gorkemfidan
I had a master who had worked at the Peugeot Service for 28 years and used original parts. The problem did not improve unless we used the original parts and re-encoded the parts with the computer. I think you should connect the car to a computer in a nice service first, look at the transmission problems, act accordingly, they will guide you. Your problem may be different.
