Peugeot 206 CC Help - Problem Solved In Answers
07.09.2021 20:01 # 1
noelabi
Hello,
2002 Model 206 CC has a lot of space on the gear lever, I think it is from the part where the gear lever is attached under the gear bellows.
/div>
I wonder if the problem will be solved if I order the part with the photo at the bottom, called the short shifter, which I found on the Internet?
< div>Thank you in advance for your help.
08.09.2021 11:47 # 2
noelabi
I went to Kadosan SRT Otomotiv today. I pointed out the excessive slack in the gear and it turned out that the problem was with the gear balance. The part price is around 460 TL, at least it can be an idea for friends with similar problems. Good forums
