Peugeot 206 Brake Switch Repair & Replacement
08.05.2020 14:02 # 1
hasimayaz
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=28
08.05.2020 14:02 # 2
metin
greetings. Are 206 brake switches and 307 brake switches the same?
I am searching on the internet for 206, but I cannot find for 307.
By the way, let me tell for friends who do not know; friends who use automatic 307 knows. After leaving the vehicle in p mode while working, it locks the gear lever for a while.
In order to remove it from position p, the brake is pressed and the unlocked vehicle can be put into gear by means of the sensor below.
Since this sensor is a chronic malfunction, sometimes we cannot move the gear from position p even if the brake is applied.
I am looking for that customer, the automatic and manual 307's were the same.
Is it the same in the 206's and it is possible for us to change it as our hostile friend tells us to change it.
08.05.2020 14:02 # 3
I want to make a slight change in what the brother says. If it works, rather than leaving it in p mode for a long time, the run is constantly locked. but when you press the brake pedal, you hear that the sword hurts and when you release the click, the sword is closed.
08.05.2020 14:02 # 4
metin
Here is when the brother is locked, it opens to the brake, sometimes I run it in the morning, then I come, then I set off, I press the brake, it does not click, it does not open the lock, I stop and restart it or as soon as I start it, I get it to the N position.
the customer needs to change.
08.05.2020 14:02 # 5
I have a 2000 model Peugeot 206 XT
I noticed that one of my reversing lamps did not light up the other day and that my brake lights did not burn, I immediately went to my uncle's shop (my uncle auto body shop) and I said that my uncle made them know from the industry. We checked the stop lamps or something, we replaced the brake sensor, the diagnostic ethics and 1 bulb. My uncle said that there is no need to change the brake sensor, he removed the brake sensor and sanded it and put it back in again, my brake lights burned.
