peugeot 206 brain failure |
| 20.05.2021 22:16 | # 1 |
| 21.05.2021 11:44 | # 2 |
Is the brain inside a metal box (ecu) Or is it the place where the fuse box (bsm) is covered with a plastic cover?
In industry they call both brains. If you tell us which one it is, we can give you an idea. If it gets better when you play it, there is cold solder or there is a problem with the cables.
| 23.05.2021 19:19 | # 3 |
The part you call ecu https://i.ebayimg.com /images/g/ymMAAOxynapRh3lE/s-l300.jpg
| 23.05.2021 19:21 | # 4 |
When I play with the wires, it doesn't respond, but if I move the brain sometimes a millimeter, it starts the starter.
| 23.05.2021 19:33 | # 5 |
Check the sockets that go into the ecu. Take out the sockets and see if there is any oxide. There were some users who solved the non-contact problem by inserting thin wires into the female socket. Since the inside of the brain is covered with insulating material, it cannot be repaired. You need to look at the sockets and cables. Actually, a good electrician will solve the problem.
