peugeot 206 brain failure
20.05.2021 22:06 # 1
efceka
My 2002 peugeot 206 1.6 XT doesn't work when I start the car, there seems to be a lack of contact in the brain, when I move it a little, there is a sound from the engine part, then it starts. sometimes it cuts off the gas while driving, it doesn't go above 2 rpm, it works unhealthy at idle, sometimes it stops and doesn't keep a day. I went to many masters, most of them are afraid to touch their hands. Someone said that you need a brain change, find a brain, someone said that even if you find a brain, you can't get efficiency without transferring the software inside, you need to take the car to Ankara, someone says that if the brain is dead, the car will not start at all, solder inside the brain has been thrown out, I don't know what to do, I don't know what to do, the car cannot be sold for a long time case . If anyone has this problem and knows how to fix it, I'd appreciate it if you could help.
