Peugeot 206 Brain (ECU)
25.06.2023 00:32 # 1
Baris.K
Hello everyone. My car is a 2000 model, 1.4-liter gasoline engine, and produces 75 hp. The engine is rough and jerky, and when the engine speed is low, it vibrates and struggles to move forward. I took it to the dealership, and it stayed there for a week. They tried four new injectors, but the problem didn't go away. The throttle system was then removed, but the problem still persisted. Finally, they told me there was no other option but to replace the vehicle's ECU. I'm also experiencing issues like idle fluctuations and accelerating on its own. My question is: Is replacing the ECU a very difficult task? Will it be difficult to remove it? Should a new one be replaced? Has anyone had these issues with an ECU before? I'm very concerned. I'd appreciate your thoughts.
27.06.2023 09:18 # 2
talip206
My 206 was also replaced with a used one. I've had no problems and used it for a long time. Finding a new one is both difficult and expensive. There's Esen Oto in Ümraniye Small Industry. Bekir Usta. He's a good mechanic, and I recommend him.
29.06.2023 17:25 # 3
Baris.K
Hello sir, what kind of problems are you having?
02.07.2023 13:48 # 4
talip206
Hello, when it got warm, it would stall while driving. It would start but not start. When it cooled down, it would start.
21.07.2023 20:43 # 5
Selant07
[QUOTE=talip206]Hello, when it warmed up, it was stalling while driving. It would start but not start. When it cooled down, it worked.[/QUOTE] Hello, I have the same problem with my car. Can the brain be repaired or do you recommend that I buy a new one?
22.07.2023 03:19 # 6
talip206
Hello. Unfortunately, it can't be repaired. There's a thick layer of silicone on the electronic board for insulation, and it can't be removed. That's why no one is willing to repair it.
22.07.2023 12:12 # 7
Selant07
[QUOTE=talip206]Hello. Unfortunately, it cannot be repaired. There is a thick silicone layer on the electronic board for insulation and it cannot be removed. That's why no one is willing to repair it.[/QUOTE] Thank you, I did not know.
13.09.2023 19:14 # 8
Yusuf Uysal
Hello, I'm new to the forum. My car is a 2003 Peugeot 206 XT 1.4 Gasoline. I need the "9650664080 BSM B3" engine fuse box. I would appreciate any help I can find.
