Peugeot 206 battery lamp and gasoline smell |
| 08.05.2020 19:34 | # 1 |
| 08.05.2020 19:34 | # 2 |
sonerkyl |
If the battery problem is not from the battery, have a look at the charger. If the smell of gasoline is drained, I say.
| 08.05.2020 19:34 | # 3 |
Light from the charging dynamo may be lit. There is a low probability, but when the battery light is on, move the contact to the left and right, follow the light and if it goes out, there is a problem in the contact part. In some cases, the contact problem is emitting battery light. As for the issue of gasoline, lift the seat of the back seat, remove the black plastic cover and check for gas leaks there. |
