Peugeot 206 auto misfire problem
08.05.2020 20:19 # 1
umut1001
Slm.Peugeot 206 auto vehicle does not eat gas when it warms up. One master connected it to the computer, called the upper oxygen sensor, we did not change the problem. Go to this master, they said you will make a direct point shot. We connected it to the computer. I went to a master, made the adjustment. I disassembled a spark plug, it looks like a bit bad, you better change it. The problem is repeated when the car warms up well. and singing)
08.05.2020 20:19 # 2
umut1001
My car is 2008 model gasoline.No lpg
Sometimes the yellow engine warning lamp comes on when it gets hot and sick. (writes ignition or injection error in user manual)
umut1001 2017-04-25 19:11:28
08.05.2020 20:19 # 3
umut1001
I did some research. Could it be from the eccentric sensor? What should I do to find it? I don't want to replace the spark plug ignition coil either, now I've already spent a lot.
08.05.2020 20:19 # 4
umut1001
I just measured the ignition coil, approximately 1.2ohm primary and 30 kiloohm.
Are these values correct? Where can I learn?
08.05.2020 20:19 # 5
talip206
Were there any situations such as oxidation when removing the bobbin tires, teacher?
08.05.2020 20:19 # 6
umut1001
I couldn't look at it. I just removed the socket and measured it. I'll look at it too. I think there are a lot of possibilities. If I go to the technical service, it will probably disassemble all parts and replace it with the new one. He took care of the lira. umut1001 2017-04-26 12:59:27
08.05.2020 20:19 # 7
talip206
[QUOTE = umut1001] I couldn't look at it. I just removed the socket and measured it. I'll also look at it. electrician master oring changed 80 lira.
Sir, if there is a problem with the coil, it is most likely oxidizing. Pull the tires off the end of the take-off coil. If the springs and ends are made of oxide, the coil is faulty.
If your hand is lying down, it will not take ten minutes to disassemble.
It is healthier to look at the voltage produced by the coil than the voltage on the coil. The input voltage value can be misled.
08.05.2020 20:19 # 8
umut1001
Hodja, I don't have a ratchet set, unfortunately.
We're not measure voltage is already resistance ölçüyoruz.çıkış tension already should be around 30b of volts and will measure this device I already do (my multimeter I measure max = 1000V DC) .Sekond winding Is there a one- or parallel 4 secondary windings is not it bilsem is actually a defective The secondary winding resistance I read on the internet is between 8 and 15 kiloohms, but around 30 kiloohms I read. Thanks.
umut1001 2017-04-26 14:03:48
08.05.2020 20:19 # 9
umut1001
Slm. I removed the bobbin. I sanded his pins and springs. I made the measurement. In the yellow terminals with 4 next to each other, 1-4 numbers show 6.5 kiloohm 2-3, 5,5kiloohm resistance. I put it back. The car is working. And the engine is shaking. Could it be a spark plug problem? I looked at the spark plug heads, there is a slight oxide. Thanks.
08.05.2020 20:19 # 10
umut1001
By the way, how many revolutions do you see when you press the gas when the gasoline automatic friends are in the park position?
08.05.2020 20:19 # 11
umut1001
Guys, the problem was overheating. I bought a sender, I said I will remove it and change it. I tightened it a bit. (
08.05.2020 20:19 # 12
Ser9239
Hello, I have a Peugeot 206 vehicle, when the engine is cold, it runs normally when it gets hot, it kicks, especially when it does too much in gas, it does less in the gas, everyone says something different, the engine does not misfire when it is cold.
08.05.2020 20:19 # 13
umut1001
I also have the same problem. Most likely it does not open the thermostat. (I changed the thermostat, the problem continues)
Or the temperature sensor is defective. When the temperature sensor is defective, the engine can show the temperature of the coolant lower than its normal temperature. So, if the customer is defective, the coolant sends incorrect information to the brain. It sends a poor mixture of gas-rich air, so that the engine gets hotter, which also causes fever.
When the temperature is around 80 degrees, take one thermometer, open the expansion tank cover. Measure the temperature. You can also measure the temperature of the radiator with the infrared thermometer. If the temperature and the temperature on the display do not match, the temperature sensor is probably broken. You will have to pay 80-90 pounds more. If your thermostat is broken, you will have the same cost. If you get two, you can handle 150.
How much fuel do you spend?
umut1001 2017-05-01 20:26:33
08.05.2020 20:19 # 14
Ser9239
206 it cooled me from living, to whom I go, I am 250 feet above the oxygen sensor they said, changed the fault, deleted the injector malfunction they said, I bought the injector again, I bought the same coil again, they said the same spark plug again, I put it in the same customer again, I have been researching for a couple of days. There is no thermostat in my car, no misfire when the engine is cold, but when it gets hot, it kicks excessively in the gas, it makes it lighter in the gas, it doesn't cause the gas in the gas, or I misunderstand it.
08.05.2020 20:19 # 15
umut1001
Maybe because gas and gas brains are different
08.05.2020 20:19 # 16
umut1001
How many models is the vehicle?
08.05.2020 20:19 # 17
Ser9239
My car makes 201 models very light on gas, hard to feel, when it is hot, there is an excessive misfire in gas, and there is no room in gas when it is cold
08.05.2020 20:19 # 18
Ser9239
Did your car recover when you changed the sender
08.05.2020 20:19 # 19
umut1001
Here I was going to test it today, I took the long bite to get it done. I bought a ratchet wrench.
08.05.2020 20:19 # 20
Ser9239
I am definitely waiting for your news.
Page : / 3
