Peugeot 206 AUTO has a play in the shift cable
08.10.2022 14:37 # 1
Mesutaslan
I showed it to 4 different masters, some said that the rope will change, some said that the electronic reader on the rope will change. I took it to the Peugeot authorized service and asked for 800 TL for the determination of the malfunction. Plus piece fee. I took it to the Automatic Transmission, he said there is a rope gap in the gear. He said the rope will change. 1600 TL fee is zero. Plus labor charge. Isn't there any other method for this or will the rope have to be changed? When I slide it 1 cm to the right and left, the gear shifts to the position I want.
08.10.2022 18:58 # 2
talip206
It may be due to the gear position switch. So the part you call the reader. Try disassembling and cleaning first.
I've never heard of a rope failure.
08.10.2022 19:46 # 3
Mesutaslan
Is there a loophole in the rope? In other words, when you slide it 2 cm to the right and left, there is a gear shift. So I'll take it from r to n, for example. I'm going to put it in the slot in the gearbox. As I said, this transition happens when you swipe left and right.
