Peugeot 206 & 307 Hour LCD screen removal
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 14:10 # 1
hasimayaz
307
206 2004 and Above
sonerkyl 2016-08-17 13:43:26
08.05.2020 14:10 # 2
BERKAN
thanks for your sharing. I will have one more question. I have a 2005 model xline hdi 206. I am missing some articles on this screen. does it have a repair? Where can I have it done? If you do not have any information about the price of this, if I take the zero and where can I confirm it? thanks already ..
08.05.2020 14:10 # 3
If a friend was selling 3 lines, it was broken and I would buy 3 lines.
08.05.2020 14:10 # 4
BERKAN
When I buy 3 lines, will I sleep there or do I have to play outside?
08.05.2020 14:10 # 5
fits of course
08.05.2020 14:10 # 6
crms
Are there any people who can tell how they are made?
Respects...
08.05.2020 14:10 # 7
Muhammet CAKIR
[QUOTE = baytonosis] thanks for sharing. I will have one more question. I have a 2005 model xline hdi 206. I am missing some articles on this screen. does it have a repair? Where can I have it done? If you do not have any information about the price of this, if I take the zero and where can I confirm it? thank you already .. [/ QUOTE] the reason why the text is getting hot is because some of the bulbs inside it burst.
08.05.2020 14:10 # 8
inceyasar
Greetings do not show up on my screen. Where can we find these bulbs? Do these bulbs work with 12 V?
08.05.2020 14:10 # 9
[QUOTE = inceyasar] greetings do not show up on my screen. Where can we find these bulbs? Are these bulbs working with 12V? Can't we replace them with LEDs? [/ QUOTE]
Even if the bulbs are completely cut, you should be able to see very little text on the screen.
You can replace the bulbs with LED, in the forum, it is explained how to make applications under the necessary headings.
08.05.2020 14:10 # 10
Haksen016
thanks for sharing.
08.05.2020 14:10 # 11
inceyasar
I changed the bulbs, no problem, thank you for now :)
08.05.2020 14:10 # 12
I just unscrew the top cover of my vehicle and now the left side looks dim, what could be the problem. I didn't damage the screen, though. I don't understand why it happened
08.05.2020 14:10 # 13
inceyasar
dude, the bulbs might be a little sensitive
08.05.2020 14:10 # 14
[QUOTE = Inceyasar] dude the light bulbs might be a little sensitive maybe maybe [/ QUOTE]
let me check it out.
08.05.2020 14:10 # 15
revolutionary26
Would it be a difference if we change the color of the leds on the display panel of the 307?
08.05.2020 14:10 # 16
[QUOTE = revolutionary26] Would it be a difference if we change the color of the leds on the 307's instrument panel? [/ QUOTE]
There is no original LED on the instrument panel. Bulbs were also used there. But you can turn it to LED. There are applications.
08.05.2020 14:10 # 17
dinoco
where can we find led bulb?
08.05.2020 14:10 # 18
Muhammet CAKIR
[QUOTE = dinoco] where can we find the led bulb ?? [/ QUOTE] you can not get efficiency with the led bulb my brother here distributes yellow even if the background is blue reflected. transparent, so you have to do it without color or you have to use the yellow bulb
08.05.2020 14:10 # 19
Led bulb is not just Led. If you say LED bulbs, Led lamps used in homes for saving purposes come to mind that it will be a little difficult to get it there. Göz Kırpma
Led, even the SMD Led you will use there because the view of normal Led:
Even this Led is great for that little space. Instead, there are small LEDs called SM LEDs and you can solder them directly on the printed circuit. Another advantage of SMD LEDs is that the light emitting angles are around 120 degrees.
These SMD LEDs are also used in products sold in the market as Serit Led. You can obtain these LEDs from all electronics markets. However, if you do not have the experience of connecting it, do it with a connoisseur because you will see 12 volts in the indicator circuit while these leds are working around 2-3 volts.
Koliva 2011-04-26 09:08:48
08.05.2020 14:10 # 20
revolutionary26
I changed the bulbs it was 2 days, I went long on this day, it showed nothing Wall
Page : / 3
