Peugeot 206 airbag light pictured
31.01.2021 14:16 # 1
Emresertbas
Hello, the airbag light is on. It has been about 1 year since the day I bought the car. My vehicle is Peugeot 206 xt 2003 model. If anyone knows how to fix this problem, I'd appreciate it
-Drive cartridge 1. Circuit is short circuit
< b> -mecvut
This is the message given by the computer
01.02.2021 01:07 # 2
talip206
Hello, first of all, remove the plastic part of my steering wheel where the signal and wiper arm are. There are sockets at the bottom. The brown one is the airbag socket. Often dislodged or oxidized. Check it out and do it.
02.02.2021 20:42 # 3
rolandgarros
Is the airbag light on the driver's seat or passenger side? If the driver is, you have to apply the method that he calls the aspiring brain. Before removing the airbag, it will be useful to remove the battery terminal. If the passenger airbag light, the solution is simpler. By inserting the ignition key into the key input at the bottom left of the steering wheel, the passenger airbag can be switched on / off.
15.02.2021 18:37 # 4
Emresertbas
he gave the warning as driver in the computer
