peugeot 206 airbag light and speedometer and stop |
| 29.06.2022 19:56 | # 1 |
| 01.07.2022 22:06 | # 2 |
Hello. Actually, the airbag light is a result, not a problem. If the speed needle goes down to zero while the vehicle is in motion, the airbag light will turn on, this is normal. This is how we can tell if the mileage sensor is faulty. When the speed needle goes to zero, follow the odometer traveled, if the km does not progress, the km sensor is defective. For example, the needle went to zero, you are on the move, you have traveled 2 km, but the odometer does not advance, then the problem is in the km sensor. If the km increases, the problem may be in the display or the brain. |
| 01.07.2022 23:01 | # 3 |
Sir, when the speed needle goes down to zero, km does not progress, then my km sensor is faulty. Stopping occurs due to this, sir, the speed indicator goes down, the airbag light turns on, and then when you change gear or slow down, the vehicle stops. Does stopping have anything to do with it?
| 03.07.2022 23:23 | # 4 |
Then the mileage sensor is faulty. Stop may be related to this, but I can't say for sure. Sometimes this can happen in brain malfunctions as well. Go from cheap to expensive. Change the mileage sensor first.
| 12.10.2023 10:47 | # 5 |
Was the problem with the speedometer? Was the problem fixed? I have the same problem. My mechanic said that if the speedometer was replaced, the problem would go away. But what did you do? Thank you.
