Peugeot 206-207-307-308-407 etc. Spare key |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 20:23 | # 1 |
sonerkyl |
| 08.05.2020 20:23 | # 2 |
OguzhanKucuk61 |
I did not fully understand the event, brother. What chip is this?
| 08.05.2020 20:23 | # 3 |
sonerkyl |
Oguzhan, this chip has immobilizer security system inside our keys. I did not have a spare key, now I have solved 40 TL. Auto keymakers want around 80 TL.
| 08.05.2020 20:23 | # 4 |
OguzhanKucuk61 |
[QUOTE = sonerkyl] oghuzhan this chip has immobilizer security system inside our keys, the car doesn't work when it is not chip. I did not have a spare key, now I have solved 40 TL. auto keyers want around 80 TL. [/ QUOTE] I understand, good luck :) I want a key with a trunk release button. I will engage in the auto unlocking event with the door lock motor. I plan to make buttons inside (examples are available) I want to open it from the key as well. @BLACK LION. |
| 08.05.2020 20:23 | # 5 |
Sir, can you give me detailed information, how did you introduce the chip?
| 08.05.2020 20:23 | # 6 |
dejawu1978 |
soner master me in the key i think the spare key is in me ... there is no button or something i have an external alarm i guess the car will not start even if the tip is in the new remote, there are pictures at the bottom, i will be happy if you help what you need to do with the button and also how is this introductory event
| 08.05.2020 20:23 | # 7 |
Oktkor |
You will get a blank key case with chip key. You will go to a normal keymaker and open the tip. Then you will introduce the chip in the empty container you bought with its device and your own immobilizer. I know there is immobilizier in the spare key but it doesn't support when it is keyed. If you say you only have a switch without a key, open the normal end and put the chip inside the spare key inside the switch. This much. |
| 08.05.2020 20:23 | # 8 |
dejawu1978 |
oktkor please do you want to send a link .. know exactly what i will get out for now i thank you for cvp
| 08.05.2020 20:23 | # 10 |
That spare key issue cost me 150TL. If I know which chip I need to buy, I get it immediately for the extra spare key, but I don't know where to code it. Is there a friend to help you in Istanbul? How can we understand what chip is there by looking inside the existing key
| 08.05.2020 20:23 | # 11 |
Oktkor |
There is a code in the work of the key switch, look at it. For example, I was writing this. ![]() Then there is the knife type and they call it VA1 VA2 or something. Some blades have a flat edge and some are recessed. Then there is the chip issue. There are two different criteria in him. One is the frequency value which usually has 433 and the other is the chip code. Here it changes according to different shapes. Key operated, etc. After getting all this, go to the unlocking and open the knife and code the chip and then introduce it to the vehicle. This much. The hardest part is to code the chip. Others are not even an issue. |
| 08.05.2020 20:23 | # 12 |
[QUOTE = Oktkor] There is a code in the job of the key blade. For example, I was writing this. ![]() Then there is the knife type and they call it VA1 VA2 or something. Some blades have a flat edge and some are recessed. Then there is the chip issue. There are two different criteria in him. One is the frequency value which usually has 433 and the other is the chip code. Here it changes according to different shapes. Key operated, etc. After getting all this, go to the unlocking and open the knife and code the chip and then introduce it to the vehicle. This much. The hardest part is to code the chip. Others are not even an issue. [/ QUOTE] Sir, the frequency value of my car had to change, so the key has changed on the chip. That's a long story. So it would be wrong to write on the key. |
| 08.05.2020 20:23 | # 13 |
sonerkyl |
[QUOTE = prdxy] Sir, can you give me detailed information, how did you introduce the chip and I need to have a spare key [/ QUOTE] Let me tell you that I bought id46 chip from aliexprest. It costs $ 2 and the empty container costs about $ 2. Of course, we will go to a special service with the original software of PP2000 Peugeot, after that, of course, the vehicle must have a securty code card before it. There is a 4 letter code in the card to introduce it to the vehicle. It can be obtained from authorized services. It is necessary to go with vehicle and license subject to this code. Of course I do not know how much service will charge. If the keymen do not have this code, they charge an extra fee between 50 and 100 TL.
| 08.05.2020 20:23 | # 14 |
sonerkyl |
[QUOTE = uzunca961] This spare key issue cost me 150TL. If I know which chip I need to buy, I get it immediately for the extra spare key, but I don't know where to code it. Is there a friend to help you in Istanbul? How do we know what chip is there by looking inside the existing key [/ QUOTE] hocam without control, if you want, it can be taken care of in special services chip (immo) type same id46 chip in you. you will only get 2 dollars uncapped container, you need to have a securty code card back to the vehicle, or you need to get it from the services to promote it with the peugeot planet program. I am waiting for the product that will come from China for the fabric. Let's see if we can introduce it. sample link For example, the code card type of my 206 may look a little different, for example in your vehicles. ![]() |
| 08.05.2020 20:23 | # 15 |
sonerkyl |
[QUOTE = dejawu1978] soner master, I think the key is in the key, I think there is no button ... I have an external alarm, I guess if I keep the tip on the new remote, the car will not work, I have the pictures at the bottom. [/ QUOTE] my teacher probably got an alarm later because they lost your remote key. I bought a remote control key, I'm waiting for it to come and let's see if we can introduce it to the car. I bought only chip and container is a trouble-free diagnosis. Origin key is required to introduce the fabric key by ourselves.
| 08.05.2020 20:23 | # 16 |
[QUOTE = sonerkyl] [QUOTE = Uzunca961] This backup key issue cost me 150TL. If I know which chip I need to buy, I get it immediately for the extra spare key, but I don't know where to code it. Is there a friend to help you in Istanbul? How do we know what chip is there by looking inside the existing key [/ QUOTE] hocam without control, if you want, it can be taken care of in special services chip (immo) type same id46 chip in you. you will only get 2 dollars uncapped container, you need to have a securty code card back to the vehicle, or you need to get it from the services to promote it with the peugeot planet program. I am waiting for the product that will come from China for the fabric. Let's see if we can introduce it. sample link For example, the code card type of my 206 may look a little different, for example in your vehicles. [/ QUOTE] Unlocking the pin code, he solved the card in a car I wrote. But if I want to make a spare key, I don't know which chip to buy. The chip model inside the key has changed. According to the keymaker, it was the same chip as the 207s. I even asked me to sell a 3-button container, I said no need. I wonder if there is anything to make us understand the chip.
| 08.05.2020 20:23 | # 17 |
sonerkyl |
My teacher will send the same id46 list of 207 and 308 chips. Domestic vehicles are only a few different in old new models in peugeot with 95% id46 chip. list link http://transpondery.com/transponder_catalog/peugeot_transponder_catalog.html There are such codes on the chip, my teacher seems a little difficult. If you can read it starts with pcf and then ends with the number 7936 or 7941. It is called PCf7936 (id46) chip. ![]() |
| 08.05.2020 20:23 | # 18 |
[QUOTE = sonerkyl] Let me send the same id46 list of 207 and 308 chips for my teacher. The vehicles sold domestically are just a few different in old new models in peugeot with 95% id46 chip. list link http://transpondery.com/transponder_catalog/peugeot_transponder_catalog.html There are such codes on the chip, my teacher seems a little difficult. If you can read it starts with pcf and then ends with the number 7936 or 7941. It is called PCf7936 (id46) chip. ![]() When I go home, the first thing I will do is look at the chip. I'll take a picture of whatever can be read on it
| 08.05.2020 20:23 | # 19 |
sonerkyl |
All right, but as I said, id46 chip is probably not a different chip. Nice to have you securty code. |
| 08.05.2020 20:23 | # 20 |
The immo chip (id46) also needs to be programmed, is there a device for it? And if you give your chassis number, I can find out the pin code if anyone wants to get it done.
