Peugeot 206+ 2011 petrol misfire
08.05.2020 19:01 # 1
bodrumlu48
hello friends my name is kemal bodrumlu 3 days ago i decided to join you by buying a peugeot 206+ 2011 gasoline comfort 2.el 60.000 km :) friends when i bought the car there was no problem 3 days later the car burned the engine fault warning 4 thousand cycles started to not pass when i bought gasoline I changed the coil of the vehicle today, we did not solve the problem, we put the coil back, renewed the spark plugs, we looked at everything, we couldn't solve the problem, the master said that it could be a dirt in the fuel, and gave my petrol mixture to the tank, I drove 100km, the problem was not solved when we connected it to the computer, the 1st piston gave an insufficient ignition warning when we connected it to the computer. There is no problem when I put the vehicle in gasoline when it gets stuck in the tube. There is a little misfire. Cry
08.05.2020 19:01 # 2
bodrumlu48
I wonder if I have a friend who can help :(
08.05.2020 19:01 # 3
cansalci
Me was the opposite, so when I was on LPG, I was in trouble with kicking.
We changed the coil and spark plugs, cleaned the bidet butterfly and the problem was solved.
I hope you find a solution. Get well soon
08.05.2020 19:01 # 4
bodrumlu48
friends, I changed the spark plugs, we changed the coil, we looked at the problem, it was the problem, they were not, then when I went to another master, I said that the problem was fuel, I put the cLEANER and filled the tank, but the problem has passed, but I must have removed the same problem today.
08.05.2020 19:01 # 5
Alicilik
[QUOTE = basement48] friends have changed spark plugs, we changed the coil, we looked at the problem, it was the problem, when I went to another master, I said that it was the problem of fuel, I put the cLEANER and filled the tank, but the problem went away today.
Complete the entire tank, 100km will not be fully cleaned.
Have spark plugs and cables injectors checked.
Clean the pipe of the Egr valve
Clean the throttle.
Replace the filters and gasoline filter in the gas brain,
