Peugeot 206 2004 1.4 lpg petrol misfire |
| 08.05.2020 21:25 | # 1 |
| 08.05.2020 21:25 | # 2 |
sonerkyl |
Hodja, first of all, you did not pay attention to gasoline. if there is no problem with gasoline, the problem is probably either in the lpg setting or in the coils
| 08.05.2020 21:25 | # 3 |
There is the same problem with gas, even when you were riding on gas at first |
| 08.05.2020 21:25 | # 4 |
bakar16 |
I had such a problem, I opened the air filter and looked soaked. If it is raining, check if you are getting water from the lower boiler.
| 08.05.2020 21:25 | # 5 |
No, my teacher changed the air filter or something, oil changes were made, spark plugs changed, gasoline filter changed, after these maintenance, he started not to eat gas.
| 08.05.2020 21:25 | # 6 |
If the problem has come out after maintenance and is only making this malfunction for a short time of 10 seconds, it may be a problem with the throttle. .? Now if I say spark plug etc, it does it all the time. Adaptation was required after the throttle cleaning. If the throttle has a servo motor, this condition is already. This could be an estimated problem. Have you got this done? Also, is your throttle with rope or servo motor?
| 08.05.2020 21:25 | # 7 |
Hodja, while I was working on the vehicle, I said to the master, let's clean the throttle. I bought the lining spray and the master cleaned it. Rope Teacher
| 08.05.2020 21:25 | # 8 |
I think the problem has been solved, we have connected the computer to the injector malfunction, but I will get on like this because it is not completely damaged. For now, he does not put it on the road, he does not do it all the time until it is broken, then we will change
