Peugeot 206 (2003) rear suspension recommendation
05.12.2020 00:15 # 1
Brcbyrktr
I need brand model recommendation for Peugeot 206 (2003) rear suspension.
05.12.2020 10:16 # 2
Berkay Erdinc
Hello, there are only shock absorbers at the back, as you know, there are no springs etc in the 206. You should choose as hard or soft shock absorbers. It does not bother like a hard shock absorber. My experience is that you can only use local Maysan shock absorbers between these two brands.
06.12.2020 20:26 # 3
Brcbyrktr
Thanks for the answer. These cartridges are part of what you call, supplied separately from the shock absorber? I also heard a piece called suspension wedge..It is not enough to just buy a shock absorber, but I also need to provide these parts.
06.12.2020 22:02 # 4
Berkay Erdinc
[QUOTE = Brcbyrktr] Thank you for the answer .. These cartridges are part of what you call, supplied separately from the shock absorber? I also heard a piece called the suspension wedge. It is not enough to just buy the shock absorber, but I also need to provide these parts .. Unfortunately, the repair shop also has tweezers and the material information .. [/ QUOTE] In general, the moving metal parts are not fixed directly to the metal parts where they will be fixed. They are fixed with plastic wedges, rubber, etc. materials called cartridge bushes between them. These parts serve to soften the vibrations of the knock. The simplest example for your better understanding is the engine mounts. The more quality the shock absorber cartridges are, the longer the shock absorber life will be. When you say the suspension wedge, it is called torsion bushing. 4 pieces. Again, the task is to absorb the shocks and reflect the minimum impact to the chassis. or wheels When it falls into a pit like any, it sounds like GUM, so to speak.
06.12.2020 22:35 # 5
Brcbyrktr
Then I need to understand this briefly.? Torsion is not my problem ... only the shock absorbers will change and I just need to buy the shock absorbers. It is a cartridge, it is a chock, I do not need to buy it. is not it?
06.12.2020 22:46 # 6
Berkay Erdinc
[QUOTE = Brcbyrktr] So briefly I need to understand this?. Torsion is not my problem ... only the shock absorbers will change and I just need to buy the shock absorbers. It is a cartridge, it is a chock, I do not need to buy it. is not it? [/ QUOTE] Now I do not know your complaint. Maybe your shock absorber or all your torsion is intact. You go to a front trimmer (tie rod balancer) and have them look at your car. They will tell you if there are broken parts or parts and you will move when this is straightened.
