Peugeot 206 185/65 r15 winter tire
08.05.2020 20:08 # 1
plawert
Hello friends,
I have to wear a winter tire on my Peugeot 206 with a mandatory travel. My friend has 185/65 r15 tires in idle. Does it rub when I put it on, did anyone use this size of rubber before? I'm waiting for your help...
08.05.2020 20:08 # 2
onlycihan
This size is not suitable, it exceeds more than 3 percent difference between the original and fuel consumption.
08.05.2020 20:08 # 3
plawert
Fuel consumption is not a problem, I will not use it for a long time. The important thing is that I do not want the rubbing to rub and damage the hoods in turns.
08.05.2020 20:08 # 4
OguzhanKucuk61
Original size of 175/65/14 species. Observe this.
08.05.2020 20:08 # 5
plawert
I have been using 185/55 r15 for 5 years, I am very pleased, as I said, there is a temporary situation, otherwise I am not in favor of going out of certain dimensions.
08.05.2020 20:08 # 6
OguzhanKucuk61
185 55 15 is the original size. When you look at the total diameter, it is 2 mm. So it is unlikely that you will even choose it with your eyes. But if you attach 185 65 15, the difference in the total diameter is 6.5% (recommended max. 3%) will increase by 40 mm. You can look at the event as 2 cm extra will enter the fender and the vehicle will rise 2 cm.
08.05.2020 20:08 # 7
OguzhanKucuk61
Rubbing on hoods in turns is related to the floor width. If you turn a full turn at 185 floors so far, it will not happen if there is no rubbing. The problem now is not raising the cheek height from 55 to 65. oguzhankucuk61 2017-01-11 22:02:30
08.05.2020 20:08 # 8
plawert
Does that 2 cm height cause rubbing? I guess we will not be able to understand this without trying
08.05.2020 20:08 # 9
Gokcesel
I was using 185/65/14, I did not have any problems, but I can not estimate 185/65/15, those who use it usually use 55 cheeks.
08.05.2020 20:08 # 10
plawert
I have 55 sidewalls on my own tires but I don't have to wear winter tires for a short time I don't want to bind money
08.05.2020 20:08 # 11
OguzhanKucuk61
[QUOTE = plawert] Does that 2 cm height cause rubbing? I guess we will not be able to understand this without trying [/ QUOTE]
More knowledgeable friends can convey more clearly what such a rate will have. You are right, one set of tires for at least 500-600 ₺. God give convenience.
08.05.2020 20:08 # 12
plawert
Eyw let's see if we try and see if there is rubbing
08.05.2020 20:08 # 13
ggitaristt
The tires you are using now do not rub if there is a distance of 1 cm to the places you are afraid of rubbing.
