Peugeot 206 1.6 110 Hp misfire when hot
03.05.2022 19:51 # 1
Ferhat AYAZ
Greetings from the sentence, my friends
206 I have a 2004 model quiksilver when I bought it, there was no problem when I got it, I've been riding it for about 1 month.
There is a rattle, misfire and shaking in the gas and gas in the vehicle, it doesn't do it when it's cold, it rattles when it's over 70 degrees, as if the helicopter is taking off. And after 3 thousand cycles, the car starts up. I changed the spark plug, when I connect it to the odb device, I get the evap canister valve failure
has the engine beexa light on? has it happened
06.05.2022 08:48 # 2
Hello aleykum. If there is a problem in the canister in the ignition system, such problems can occur. There is mas peugeot abdurrahman master in ivedik, I recommend you to go and get information if you want.
17.05.2022 13:57 # 3
Ferhat AYAZ
PROBLEM SOLVED.
Friends, a short spark plug was installed on my vehicle. The problem was solved by reinstalling the original long spark plug.
for your information.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
