Peugeot 206 1.4 Hdi - Max Speed?
08.05.2020 15:45 # 1
cuneytatay
Hello friends
On the way to Istanbul on the weekend, I said, let's try a speed while he is available on the road.
The car reaches 160 km at 3750 rpm in 5th gear and does not accelerate further, is this normal?
What is your situation?
08.05.2020 15:45 # 2
metin
There is a video of the vehicle of our member named Albaydemircan with the same engine and model in our forum.
you can make your final speed comparison,
08.05.2020 15:45 # 3
hallowman2005
According to speed, normal speed alone has a big impact on the slope of the road. Let me give you an example, my previous vehicle is the 2006 model 206 1.4 HDI and 210 km speed between Ankara and Istanbul, but when I go down the ramp on the slightly inclined road, again on the same road without inclination, it is 170 - 175 km at 4000 rpm, but this time it is max. at speed (depending on the vehicle's traction) the max speed is 150 km.
08.05.2020 15:45 # 4
cuneytatay
this is the video
[TUBE] ow8ldd7htm the [/ TUBE]
08.05.2020 15:45 # 5
The average face of 206 hdi is like 180 ... You can see a further increase in the ramp down ...
08.05.2020 15:45 # 6
Reaching 175-180 km speed my cengaver Clown
08.05.2020 15:45 # 7
cuneytatay
so my yogican :) why not speed up more?
like it doesn't allow it electronically?
08.05.2020 15:45 # 8
Have a look at the press pad maybe there is a kidnapping. when was the last time you changed the air filter
08.05.2020 15:45 # 9
How is the maintenance status of the engine ??? filters, injectors, turbo vs engine power may not be more efficient if it is low.
08.05.2020 15:45 # 10
cuneytatay
I bought the vehicle at 182,000 and I don't know what has changed at about 197,000 now. the filters have changed but i don't know the other parts exactly, i get my fuel from po always, how long should i change the filters and the masters how can i be sure of what you have written.
08.05.2020 15:45 # 11
hallowman2005
The fuel of Cüneyt pon may be slightly lower in performance than shelle. In any case, after consuming the fuel in your vehicle to the end, take fuel from the shelter and try it for a while to pass 10000 km for air pollen and oil filters 6 - 7 - 8 .. thousand is at your discretion. It should be done once every 2 oil changes in the diesel filter. I watched your video, the first three gears are normal in the gear changes of your car. Your acceleration has slowed down a little at 4. Finally, I still believe that the vehicle speed is normal because road conditions and vehicle load conditions at max speeds are the major factors affecting speed. hallowman2005 2011-07-05 19:08:30
08.05.2020 15:45 # 12
insomnia
It is possible for cvt transmissions, but for the first time in synchrometers, I can say that if this road is a highway in tigarakya, I have experienced similar things.
08.05.2020 15:45 # 13
A total of 5 people, even 5.5 people with 1 child, up to the opening of the trunk, I saw 170 air-conditioning open, I was afraid that it was going to go further.
08.05.2020 15:45 # 14
cerci07
Throw away your cars, cope GKN 4
68 hp is not 200 what you expect from a vehicle, I hope that when the speed limit is 120 km, there should not be a need
08.05.2020 15:45 # 15
ask307
same my vehicle 307 1.4 hdi stopper exactly same 3750 rpm 165 or something like top speed pad changed but it didn't matter much
08.05.2020 15:45 # 16
cuneytatay
[QUOTE = hallowman2005] Cüneyt pon's fuel may be slightly lower in performance than shelle. In any case, after consuming the fuel in your vehicle to the end, take fuel from the shelter and try it for a while to pass 10000 km for air pollen and oil filters 6 - 7 - 8 .. thousand is at your discretion. It should be done once every 2 oil changes in the diesel filter. I watched your video, the first three gears are normal in the gear changes of your car. Your acceleration has slowed down a little at 4. Finally, I still believe that the vehicle speed is normal because road conditions and vehicle load conditions at max speeds are the major factors affecting speed. [/ QUOTE]
As you said, the fuel in my vehicle is over today, I will try and get it from the shell this time. While doing this experiment, I was the only one in the vehicle, so I pressed the phone to the steering wheel, I took the shot :) There is a flat part between Sapanca and Izmit.
the vehicle has undergone 2 oil changes, the master diesel filter need not be changed, he said. Let me change the other filters, I will try again according to your recommendations. thanks
08.05.2020 15:45 # 17
cuneytatay
[QUOTE = insomnia] This is possible with CVT transmissions, but for the first time in synchromesh, I actually said that if this road is a highway in the whole of the country, I have experienced similar things [/ QUOTE]
The road I tried was a straight road with no slope between sling - izmit, it was empty in the morning, the road was empty, I was going to education in Istanbul, then I was alone in the car, I did the speed trial under these conditions.
