Peugeot 206 1.4 Desire sudden rise in temperature |
| 08.05.2020 20:03 | # 1 |
When my vehicle is driving on the long road, when the temperature indicator is at the bottom, it suddenly makes the roof and stop warning. So fast, why is it suddenly ceilinged? For example: While driving at 90 km, I used it when the revolution was 2800, suddenly a stop warning came, whereas the temperature was at the bottom.
| 08.05.2020 20:03 | # 2 |
corrupt
| 08.05.2020 20:04 | # 3 |
The client may be corrupt The thermostat may not have opened There may be air in the system |
| 08.05.2020 20:04 | # 4 |
The sender said like a new master today. He did not see any trouble in the thermostat. Does he do it from the fan role? Suddenly, a stop warning is coming, and the temperature is rising. It goes from the bottom to the red: s
| 08.05.2020 20:04 | # 5 |
I couldn't understand what is corrupt
| 08.05.2020 20:04 | # 6 |
If the problem is not in the thermostat, if the thermostat is opening or if it is running, check whether the car is activated or not. If the fan is activated, the indicator may be defective. If the fan does not start, your fan module is defective. |
| 08.05.2020 20:04 | # 7 |
Thank you radox. Is indicator customer failure an expensive problem?
| 08.05.2020 20:04 | # 8 |
No, the price of the customer is 20 30 TL.
| 08.05.2020 20:04 | # 9 |
Thank you, I will deal with this problem tomorrow.
| 08.05.2020 20:04 | # 10 |
You're welcome
| 11.04.2023 14:35 | # 11 |
hello teacher, I'm resurrecting the subject, but I've been having the same problem for a long time, but I couldn't solve it. only on the long road, on the ramps and over 3000 rpm (110 - 120 km later), when the temperature is around 90, it suddenly reaches the end and the stoplight turns on. fan switch (temperature switch), fan relays, thermostat etc. have all changed. I can't solve the problem. did you solve it?
