peugeot 205 night work problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 19:04 # 1
directerdem
I have a 1992 model peugeot 205. My car runs late on the first run. Then, when I stop the car and try to start it again after 5-10 minutes, the car does not pick up the starter. I turn the ignition for 20-30 seconds but it works when the accelerator pedal is pressed. What would be the reason?
08.05.2020 19:04 # 2
monalos
Starter motor could be the same in me.
08.05.2020 19:04 # 3
directerdem
Well, how much do we need to change this?
08.05.2020 19:04 # 4
duhanaras
Hello friends, I am troubled by the same issue, I do not buy a starter without giving gas to the car.
08.05.2020 19:04 # 5
fætih
how can the starter motor be? If the starter is pressing, the starter motor is not troublesome let's pass it.
1. Check the vehicle's oil water. you may have burnt gaskets. mazda 626da came to us the vehicle was starting too late, gasket changed, valves changed, problem improved. if there is no problem with them.
2. Is there any LPG in the vehicle? If there is, first, stop the vehicle before stopping 4 4 5 minutes, stop, will the same problem continue in the morning? or close the LPG from the valve and use it for 1 2 days. if the problem is resolved, the regulator says gas is leaking.
The third contract has caused this breakdown in thermic temprada. extends the anthem.
4. You can even measure the battery from the battery.
08.05.2020 19:04 # 6
duhanaras
In my car, the oil temperature indicator does not rise today, I searched on the internet but if it does not work in vain
