PEUGEOT 2008 SEMI AUTO VEHICLE CIRCUIT IN THE FIRST DEPARTURE
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 21:14 # 1
Hasan2008
I have a Peugeot 2008 1.6 e-hdi 2013 model semi-automatic vehicle. In the first departures of Km 105000, the vehicle does the nipple (sudden take-off and vibration) service 90% of the press said to the battery. The first take-offs are not shifting outside, there is no low traction. Thanks in advance for your solution-oriented comments.
08.05.2020 21:14 # 2
First of all, welcome to us. In semi-automatic systems, this problem is generally caused by the pressure and flywheel. Another possibility is to have the engine and transmission chocks checked. If you are taking your vehicle to the authorized service, you can have it guaranteed with a good bargain. If you are going to have it in private, I will help with both parts and master in Ankara. sonerkyl 2019-05-24 09:45:24
08.05.2020 21:14 # 3
Hasan2008
Good day teacher thank you for your answer. It has been five months since I received the vehicle. If the master you recommend is peering, Peugeot will be pleased.
08.05.2020 21:14 # 4
Hasan2008
Is there anyone you can recommend for the master?
08.05.2020 21:14 # 5
talip206
The automatic clutch point of the vehicle is not enough as the pressure pad decreases in the semi-automatic gears. I recommend you to have calibration at the authorized service before replacing the press pad. After calibration, the vehicle adjusts the grip point according to the new position of the press pad.
Of course, this is a possibility. Since your vehicle has a low mileage, it is likely to be calibrated. Otherwise, the pressure must change. There are many people in Ankara who recommend Fatih Peugeotu as the authorized service. I have no idea about private.
08.05.2020 21:14 # 6
Hasan2008
My teacher had a calibration adjustment in the service, it was good for a while and now it is still a problem. Service attracts high prices Do you have the exact communication information of the place you call Fatih Peugeot, and this problem could be from a system called seleloid. (I am no stranger to the vehicle, nor do I have any information about the special service or the vehicle information)
08.05.2020 21:14 # 7
talip206
Then there is not much to do. It seems that the pressure will change the pad.
Address : BÜYÜK SANAYİ SİTESİ VEGETABLE BAHÇELERİ CAD. NO: 28 (BACK OF ÇEVİK KUVVET) ALTINDAĞ / ANKARA Company Name: FATİH PEUGEOT AUTHORIZED SERVICE Telephone number: (0312) 341 34 93
For private service, our soner friend or other member friends can also give other addresses. There may be a serious price difference between private and authorized service.
talip206 2019-09-02 18:49:55
08.05.2020 21:14 # 8
GokhaN
calibration workaround already get a price from the authorized service, most likely the pressure and flywheel will change to improve
08.05.2020 21:14 # 9
Ivedik mas peugeot var hocam printing lining will change about 3000 TL. I pass on
