Peugeot 2008 Front right window lift problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 20:28 # 1
cppmn
Greetings to all. I became a new member of the forum. I own the 2014 model Peugeot 2008 HDi Allure. My car's front right window does not close at once after it has fully come down. It rises and stops a few cm each time. I tried this from the button group on the left side, and from its own button, nothing changed. I tried an application that I saw in other forums. First I lowered the window and pressed the button for 3 seconds, then closed the window and pressed the button for 3 seconds. Yes, it works, but when I stop the car, the same problem continues the next time. Tired of downloading and holding down every time. I took it to the service in Trabzon. The master (!) Came and looked and called another person, then thought they had solved the problem with the previous method, but it did not. If anyone knows the exact solution, I will pray.
08.05.2020 20:28 # 2
First of all, welcome to us. Two causes of this type of problem are either the glass lift button is oxidized. or the glass motor compression protection mode is activated. priority is my advice if there is no button replacement, there is a problem with the engine, it is not normal to reset itself when the vehicle is turned off
08.05.2020 20:28 # 3
cppmn
Thank you for the answer, but as I said, this situation disappears when the glass is fully lowered and the button is pressed. Should there be a problem with the buttons, it shouldn't always be done, or if the glass motor is defective, it should always cause problems. the problem seems to me that I can't keep this setting in memory. I don't know if other peugeot2008 users have this problem. I removed the battery cap and put it back on again so that the windows were reset. did not understand this in the service. I'm really surprised.
08.05.2020 20:28 # 4
rbatasoy
I have the same problem. In all windows. How do we solve it?
08.05.2020 20:28 # 5
[QUOTE = rbatasoy] I have the same problem. In all windows. How do we solve it? [/ QUOTE]
First of all, welcome to contact us. You have to code my teacher glasses recently. Turn on the ignition, hold down the glass lowering hand, without holding your hand, wait 10 seconds after the glass is fully lowered. do the same for all windows. then reverse the same process.
sonerkyl 2017-10-06 15:52:54
08.05.2020 20:28 # 6
ekoklubjk
I have that same problem. Left rear window with right windshield. Glass is gradually getting up. I tried what you wrote, but it does not. The problem seems to be going first, but when the contact is turned off and on again, the problem still arises. In addition to that, I open all the windows, exit the vehicle and lock the vehicle, then, holding the lock button on the remote control does not automatically close the windows. It closes the others, two windows remain open. Where I am, I can ask no service. Is the fault in the brain? More precisely, I do not know if there is a malfunction. If anyone solves this problem, please help.
08.05.2020 20:28 # 7
[QUOTE = ekoklubjk] I have the same problem. Left rear window with right windshield. Glass is gradually getting up. I tried what you wrote, but it does not. The problem seems to be going first, but when the contact is turned off and on again, the problem still arises. In addition to that, I open all the windows, exit the vehicle and lock the vehicle, then, holding the lock button on the remote control does not automatically close the windows. It closes the others, two windows remain open. Where I am, I can ask no service. Is the fault in the brain? More precisely, I do not know if there is a malfunction. If anyone solves this problem, please help. [/ QUOTE]
Welcome to us first. There is a problem with the glass opening system, teacher. This complaint exists in many peugeot 2008 users, but nobody said that the problem was resolved. Probably related bulletin was published in authorized services.
08.05.2020 20:28 # 8
ekoklubjk
I will go to the service in Samsun as soon as possible. I will reply when the problem is solved.
08.05.2020 20:28 # 9
mehmet1
Sir Peugeot 2008 Does anyone have the problem of removing the front right window? Thanks
08.05.2020 20:28 # 10
kimiraikkonen
[QUOTE = cppmn] Greetings to all. I became a new member of the forum. I own the 2014 model Peugeot 2008 HDi Allure. My car's front right window does not close at once after it has fully come down. It rises and stops a few cm each time. I tried this from the button group on the left side, and from its own button, nothing changed. I tried an application that I saw in other forums. First I lowered the window and pressed the button for 3 seconds, then closed the window and pressed the button for 3 seconds. Yes, it works, but when I stop the car, the same problem continues the next time. Tired of downloading and holding down every time. I took it to the service in Trabzon. The master (!) Came and looked and called another person, then thought they had solved the problem with the previous method, but it did not. If anyone knows the exact solution, I will pray. [/ QUOTE]
There is almost the same problem on the right rear window. The suppositories were lubricated and coded, but the problem was not corrected. My vehicle is 208 alone.
As the above friend said, I noticed after the battery change, but why are other windows also related to coding?
the kimiraikkon 2018-07-15 18:25:37
08.05.2020 20:28 # 11
rbatasoy
Friends said the service problem was in the glass-lifting brain. But since the brain is on the glass engine, he said that the engine should change completely. They said something about 600 lira for a single glass. I didn't get it done because it was very costly. Anybody find a solution?
08.05.2020 20:28 # 12
ofabil
I have the same problem, guys, can anyone find a solution?
08.05.2020 20:28 # 13
kimiraikkonen
[QUOTE = ofabil] I have the same problem, can anyone find a solution? [/ QUOTE]
I think the problem is the window jack. It has nothing to do with the brain. The brain does not control a single glass, after all, and only one glass is problematic. It looks like a chronic problem. Shame on you. Seriously trash.
08.05.2020 20:28 # 14
muhkiraz
PROBLEM SOLVED !!!
Greetings to all. I had the same problem and I asked the friends who had this problem about a solution by message about 1 year ago from DM. I even applied to the service and told me that the glass motor had to be renewed and asked for a remarkable fee. However, the software had to be discarded during the printing + pad replacement of my vehicle recently. After the software was discarded (100 TL in private service), the problem was solved. So the problem was not the glass engine. I hope you solve the problem in this way.
08.05.2020 20:28 # 15
[QUOTE = muhkiraz] PROBLEM SOLVED !!!
First of all, welcome to us. thank you for the information
08.05.2020 20:28 # 16
boksor
I have the same problem from time to time, it resolves on its own, but I have a different problem. The right rear window rises more than necessary. thanks
08.05.2020 20:28 # 17
cihanozcelik
They said I need to change the glass motor.
the glass was opening but not closing .. u got it done with a switch ..
Though I have to buy a new one, but I can't give it 150 TL.
just before I installed a switch to the side of the open button ... I close with it .. :)
08.05.2020 20:28 # 18
rbatasoy
Where did you get the software? What exactly did he update? We will say to the man what we want to do :) rbatasoy 2019-09-06 10:23:41
08.10.2020 10:45 # 19
Mutlu40
Greetings, I have the problem you wrote, I also have a vehicle. Can you help me? Where do you make it? Religious service glass engines change check they ask for 4 thousand TL
31.07.2021 11:55 # 20
cagoto3535
Has anyone fully resolved the issue? I have the same problem on my left front and rear window.
Page : / 2
