Peugeot 2008 1.6 EHDI
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.12.2023 08:46 # 1
Ekbercem33
I'm new to the forum and greetings everyone. My car is a 2008 eHDI 2014 model. Even though I pressed the brake and shifted the gear to N to start the car, I received a warning saying, "Press the brake and shift to N to start the engine." Despite doing this several times, the car wouldn't start. Then, after I rapidly shifted the gears a few times, the gearshift sound came back, and the car started. What I'd like to know is: 1- What is the source of this problem? 2- Is this a temporary issue? 3- What can be done to avoid this problem? Thanks in advance to everyone who has provided information and contributions.
08.12.2023 09:19 # 2
Hello sir. First, have the error codes checked by a specialized service center that has original software. There could be a variety of causes. It could also be a temporary fault, such as a brake switch or position switch.
08.12.2023 10:37 # 3
Ekbercem33
Thank you very much, Mr. Soner. Your assessment may be quite accurate. Even though the battery is showing 76%, Start-Stop is not engaging.
08.12.2023 18:19 # 4
[QUOTE=Ekbercem33]Thank you very much, Mr. Soner. Your assessment may be quite accurate. Even though the battery shows 76%, Start-Stop is not engaging.[/QUOTE] The fact that the Start-Stop is not engaging is another issue. It could even be caused by the V-belt and tensioner bearings causing the Start-Stop not engaging. First of all, have the fault codes checked as your first priority.
