peugeot 107 semi-automatic chronic problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models | |
| 08.05.2020 20:19 | # 1 |
Peugeot 107 semi-automatic 2011 model 28000 km, we have 1.0 gasoline. While driving from the vehicle, there was a constant beeping sound when there was no warning. As far as I researched on the internet, it was a chronic problem in the 107s, the clutch set had to change, it says so in the forums, changing the 28000 km clutch set did not make sense to me, is there an easy solution for this? The fact that such a cost occurred on a vehicle for this km has cooled me more than the car, frankly, is a big disappointment. Is there anyone who can help with the subject?
| 08.05.2020 20:19 | # 2 |
KILIC |
How did you think my teacher was concerned with the transmission? If you are not wearing the seat belt, it may be crowing. If it is related to transmission or any malfunction, it will be written on the screen. you can hear that kind of warning when the air temperature is below 3 degrees.
| 08.05.2020 20:19 | # 3 |
Hello there, A friend mentioned here the same problem on British forum sites, they all say clutch. They even have videos on youtube. No warning, only sound.
| 08.05.2020 20:19 | # 4 |
KILIC |
So when does he do it? Does it stop and stop in very congested traffic.
| 08.05.2020 20:19 | # 5 |
uphill starts at the points where the car has difficulty, starts when it is loaded on the gas, a little bit for the head
| 08.05.2020 20:19 | # 6 |
KILIC |
[QUOTE = ccdeville] starts uphill where the car is having a hard time, starts when loaded on the gas, a little bit by head [/ QUOTE] Does it go uphill or when you take a normal uphill slope?
| 08.05.2020 20:19 | # 7 |
maximusti |
do you have esp in the vehicle? esp may be warning if it is pulling uphill paw. |
