Peugeot 107 gas beeps 4 times when loaded on the gas |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models | |
| 08.05.2020 20:05 | # 1 |
Today, when I hit the gas at the bottom, when the speed went over 2 thousand (when the car was hot), the warning sound began to beep beep beep, another friend said a clutch ax was finished, the brake pad in the authorized service changed, they thought they checked the clutch ax.
I'm waiting for an answer from friends with knowledge, thank you. |
| 08.05.2020 20:05 | # 2 |
| 08.05.2020 20:05 | # 3 |
Ask the person you bought from the lady :) Where is he holding his left foot? |
| 08.05.2020 20:05 | # 4 |
Of course I bought it from the lady :) but I am not seeing the lady I bought, a citizen who tends to hide and not say such things is already
| 08.05.2020 20:05 | # 5 |
Auspicious auspicious then someone who knows can understand very comfortably. |
| 08.05.2020 20:05 | # 6 |
sonerkyl |
teacher first, if there is a tremor in the departures, if you connect the vehicle to the computer and learn the error code, we can help you more easily.
| 08.05.2020 20:05 | # 7 |
KILIC |
Does the car also have lpg?
| 08.05.2020 20:05 | # 8 |
Hello guys, the car does not have a 1.0 gasoline LPG and there is not much I can understand about the semi-automatic gearbox, clutch, since it is automatic, what I would write here when I get a result as soon as I get to the service.
| 08.05.2020 20:05 | # 9 |
sonerkyl |
Teacher, if there is an extreme tremor in the first departures, the problem seems to be pressure.
| 08.05.2020 20:05 | # 10 |
KILIC |
So when he gives a warning, doesn't he write something on the screen? I think the weather is cold and gives me the warning of icing.
| 08.05.2020 20:05 | # 11 |
Hello friends, no warning on the screen, I showed it to the authorized service, they said that the clutch set will change, the vehicle received a price of 2.500 TL at 38.000 Km ... I am waiting for my friends who will have a reasonable suggestion for me
| 08.05.2020 20:05 | # 12 |
sonerkyl |
Honolly, the original printing pad will hold only materials between 1100-1300 TL together with the bearing around 1000 TL. authorized services keep the known labor prices high. If you say the authorized service, you can follow the maintenance and repair campaigns and reach 200-300 TL plus installment opportunity. As a special service, unfortunately, the installment is a bit difficult, maybe you can buy the spare parts in installments and give cash on labor. Of course, you need to find a good master in a private service. You need someone who will be behind the job. Of course, before I told you the fault code or something, the authorized service is crowding for this reason, the vehicle error code, etc. like
| 08.05.2020 20:05 | # 13 |
They did not give an error code, but they said that the clutch set was warming because of this, I bargained 2000 with the bargain, I got 1500 e-fifth from the services outside the service, but there is something ridiculous like this, when I call the clutch set, the product is sold at this address between 250 TL and 1200 TL. Whichever is correct, it would not be more logical if we buy it or wear it, I can also get support for Istanbul. |
| 08.05.2020 20:05 | # 14 |
sonerkyl |
My lecturer has 250 TL pressure pads for manual ones. For the semi-automatic press brake lining, around 1000 TL.
| 08.05.2020 20:05 | # 15 |
Does anyone have a proposal to do this job at an affordable price and in the Anatolian side in Istanbul?
| 08.05.2020 20:05 | # 16 |
KILIC |
If my teacher said that the service was 2000, do not get it out. I think you should have it served. Outside 500 is missing but there is no guarantee that the service is guaranteed.
| 08.05.2020 20:05 | # 17 |
I have another problem, when 2 people are sitting in the back seat, there are 2 people in the front and sometimes there are bumps in the bumps and pits, they said the car is rubbing, the shock absorbers do not break out.
| 08.05.2020 20:05 | # 18 |
sonerkyl |
My normal teacher used to have 107 in the company where I worked, 4 cars got stuck on the ground. It is normal for me to rub the small vehicle in big bumps and pits already on the wheels.
| 08.05.2020 20:05 | # 19 |
THANKS SO MUCH FOR ANY ANSWERING ALL FRIENDS
| 08.05.2020 20:05 | # 20 |
If you solve the problem and write it down, it can be useful for someone |
