Peugeot 106 XR Slowed Down Can You Help?
08.05.2020 20:20 # 1
poyraz0534
Hello friends,
I have a Peugeot 106 Xr 1998 model car Weekend tie heads - Bend Iron Plastics Changed
Rot - I got a balance. I Replaced Tires.
The car does not exceed 120. I used to see 140-160 at most. Why do you think?
08.05.2020 20:20 # 2
First of all, welcome to us. high probability of printing pads
08.05.2020 20:20 # 3
poyraz0534
Hello there,
We really enjoyed it and it has been a very useful forum.
The printing did not change the pad only it was cleared, said the master, is there something in it?
08.05.2020 20:20 # 4
Thanks, we are trying to do something different in the forum you are, hodja, when the pressure pad begins to complete its life, there are signs that the vehicle does not accelerate and fuel consumption increases. It is not a solution to clean it, the master has to lower the gearbox to clean the pad, is it a strange situation.
08.05.2020 20:20 # 5
poyraz0534
There is no problem in his work. I am currently testing fuel, in fact I bought new gas. Let's see how much it will burn.
08.05.2020 20:20 # 6
If there is no irregularity in his work, the problem is likely to lead the pressure to the pad, as I said.
08.05.2020 20:20 # 7
poyraz0534
Let me ask, then, because the pressure on the master
08.05.2020 20:20 # 8
KILIC
How to clean the press lining without lowering the gearbox. If you downloaded it, why didn't you change it?
08.05.2020 20:20 # 9
talip206
I guess the friend would say he had removed the pads and cleaned them. Otherwise, I have never heard of pressure pad cleaning.
08.05.2020 20:20 # 10
poyraz0534
[QUOTE = talip206] I guess the friend would say he had removed the pads and cleaned them. Otherwise, I have never heard of pressure pad cleaning.
tells the truth :) i told it wrong :)
08.05.2020 20:20 # 11
KILIC
I wonder if it tightens the linings.
08.05.2020 20:20 # 12
poyraz0534
will it happen? can i check
08.05.2020 20:20 # 13
poyraz0534
My problem is still going on. I went to the master, said the spark plugs.
I did not understand what could happen. I looked on the internet 1 person said to himself, .. there is still nothing clear about why. I will go to the eagle auto industry and show it to the master.
