peugeot 106 xr 98 wiper water motor problem
26.02.2022 17:48 # 1
Talha9696
First of all, hello everyone
The front and rear wiper water jet is not working. There is no sound of the Water Engine, if you know the location of this engine, can you tell me? I want to check it. And do we send water to the rear windows in a different way from the wiper arm, or when we press the wiper arm again, does it send water to both the rear and the front. Thank you very much in advance.
01.03.2022 12:10 # 2
Hello,
if you pull the wiper arm towards you, it just throws it on the windshields. For the rear glass, it varies according to some brands. If you push the arm in the opposite direction, it will throw water. When you press the wiper arm on some, when you turn the arm (usually the last step after turning the wipers on), in fact, it is indicated with signs on the arm. If you enter the chassis number of the vehicle in the link I have given, you can access the location of many parts and the part codes. There are pictures visually.
