Peugeot 106 Quicksilver, is there ABS? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 16:49 | # 1 |
edit: I guess not according to my research. is it possible for us to have abs later? As a result of this incident, I guess we could not pass the examination, but was it technically professionally done? thank you. |
| 08.05.2020 16:49 | # 2 |
tigerland |
I know that there is no. Test it yourself Braking to the end as it passes over a wet surface. When the tires reach the slip level, there is no ABS if there is no vibration in the pedal.
| 08.05.2020 16:49 | # 3 |
do a hard braking and if the brake pedal vibrates, there is a click if you feel the click it also means that the abs indicator lights up on the screen when the car starts, without switching the key to the starter position at the first start.
| 08.05.2020 16:49 | # 4 |
I know that [QUOTE = 206_XS] doesn't exist. Test it yourself Braking to the end as it passes over a wet surface. When the tires reach the slip level, there is no ABS if there is no vibration in the pedal. [/ QUOTE] [QUOTE = toga406] have a hard braking and if the brake pedal vibrates, you feel clicks Thank you for your also means that the abs indicator lights up on the display without starting the key at the first start, if the vehicle goes out when the vehicle starts [/ QUOTE] suggestion. I'm thinking of buying quik, I wanted to ask, I don't have a car. Div>
| 08.05.2020 16:49 | # 5 |
good luck good luck
| 08.05.2020 16:49 | # 6 |
KenBlockJR |
106 Quiks are very rare. I do not think the car came to Turkey.
