Peugeot 106 Ignition Key Refresh Picture
Homepage » PEUGEOT MODIFIED PLATFORM » 106
08.05.2020 14:15 # 1
okan77
Friends was a method I used in my 106 quixil tools that I used before. As with all 106, this was the problem that the button on the ignition switch lost its function as a result of its wear and tear.
Sorry I could not take a picture during the process. I can add the finished version.
It is totally my own hand ... This is from me to you ....
I will briefly explain;
First of all, we open the safe of the key with the help of coins.
Then, we select drug gelatines suitable for the buttonhole from our medicine cabinet. (Do not press it out with your hands, cracks are formed on it. You can remove the medicine with a utility knife.)
We cut the gelatin (drug container), which is suitable for the button hole, in a circular shape with a 2-3 mm frame next to them. The reason for leaving an excess is that we will use it as a button so that it does not come out of the key case ... (You can also do the same application with the appropriate remote control buttons).
Then, we fill the hollow medicine gelatins with black silicone in a way that there is no gap in them and let them dry. Now our buttons are ready ... We can use them smoothly after doing a few exercises in the key casing stage ...
For those who want to deal with a little bit .... Did not go to the stranger, but I miss 106?
okan77 2010-05-26 20:38:24
08.05.2020 14:15 # 2
FTH
Saol okan is also a must Confused
08.05.2020 14:15 # 3
okan77
Is it too complicated? Ouch There is a picture in its finished form. Adding it to the evening will give you an idea.
08.05.2020 14:15 # 4
FTH
It would be better if we could see with a blind eye. I have the same bleeding wound in me :)
08.05.2020 14:15 # 5
okan77
Now I look again, not bad .... Better than nothing.
08.05.2020 14:15 # 6
Thank you very much, I applied it, it was very nice, I made it with black silicone, it was very original :)
08.05.2020 14:15 # 7
gkn053
you thought well: D
08.05.2020 14:15 # 8
okan77
Hey the days are gone hey ...
08.05.2020 14:15 # 9
poyraz0534
the picture is gone
