peugeot 106 dial removal
08.05.2020 15:53 # 1
Burak07
Greetings to the whole PT family recently, I realized that my dial light is not fully lit and I gave it up to disassemble, but I couldn't remove it.
Although I had removed the screws here, I couldn't take it off
08.05.2020 15:53 # 2
Sedre takes the picture of water, but screws are not where you say it. It shows at the bottom. I hope the picture helps.
08.05.2020 15:53 # 3
Burak07
Thank you for your help, I think I have 2 screws under the steering wheel to remove it, but I need to unscrew it, but a thin and long socket is required because it doesn't come out.
08.05.2020 15:53 # 4
metin
You can succeed, find an Allen and continue. or there are torbavidae stems with a tightening tip on the head, so attach the appropriate torque tightening tip to the find tip.
08.05.2020 15:53 # 5
easy come bro
08.05.2020 15:53 # 6
Burak07
[QUOTE = text] You can do this by finding an alyan continue. or torbavidae stems with a tightening tip attached to the head, then attach the appropriate torque tightening tip to the find tip [/ QUOTE]
there is a widen, it comes thick and it does not enter the tip, it is fine.
08.05.2020 15:53 # 7
Burak07
[QUOTE = ahmetsimiz] easy come my brother [/ QUOTE]
thank you brother :)
